bro Danz..i ask them to check before..
my problem is like this.
1)after the second service i send to check the rotor, than that fella said he will help me to skim and replace new brake pads(DONE).
2) after doing the skimming the problem came back..that was after my third service. went back and they replaced my disc. and brake pads again.was using BENDIX METAL KING when they took away the brake pads as i changed the brake pads outside due to some noise.
3) after 3 months changing the rotor,the problem came back.after the third service i no longer went back to SC for service, so i went to check about the problem. they said i need to pay rm15 for the check and also once the solution is got i need to service my car there once in order to get warranty claim. so i walked off from the SC and emailed perodua HQ.they said there were no charges and refered me back to the SC and ask me to send my car for check up. will be doing it this wednesday, and will see wat the outcome is. changing the same rotor and the same problem arise makes no difference.
from my calculation.
after each rotor change,alignment and balancing cost rm50-60 .
change the rotor 5 times can get aftermarket which will be free from problems.
so why let them change,since this time they call me for check up than i will go and see wat they want to do.
