Need help..kancil L5 pro~
haking
25
Malaysia
Hello all sifu here..i need help...
my little kancil L5 3piston(all standard), last time when i bought back no fuel cut 1...
but last month my car meet accident n send to workshop repair, tangki bocor only...
now i get back my car i get found every gear fuel cut when 5k RPM...@@"omg..
can i know what's the pro?turbo?ecu?hmm...
thank you 1st:)
karl_razlie
514
56
5,028
Puchong
check all ur vacum hose, sensors, fuel line, fuel pump are in good condition..make sure all of them placing like OEM setting...no vacum leaks or wrong vacum hose connection..or disable sensors...then check ur fuel pump pressure izzit ok or not..... for the vacum hose u can follow the vacum route and where to connect from from ori L5 halfcut...
mag9556
2,770
43
Fuel not enough, check your fuel mapping also...
Good luck..
haking
25
Malaysia
hello sifu..me again..now i just realize even my blow off got sound but the car power totally like NA..izit my turbo kong adi? coz now cant feel the turbo power kick in around 3k rpm...help ya:(
thx thx thx~:)
karl_razlie
514
56
5,028
Puchong
follow like what i said above first..then u go expensive way...sometimes this thing happen bcoz of small matter only..like vacum leak, vacum disconnet,intercooler loose or exhaust manifold leak...BOV leak oso symptom like that one... last u check ur actuator and any strange sound when turbo spool... btw is u car emmit white smoke or other clr when accelerate?? if yes maybe ur turbo going to kong d...
Hello everyone,
I am thinking of getting a new 2016 Myvi 1.5 Auto Advance model for my wife. Any reservations from anyone for this model especially, past experiences with this 2016 model?
BOOT LEAKAGES
Was at the Authorized Service Center the other day and as I was passing-by the repair bay area, I mentioned casually that the new Myvi was leaking at the back, since there was water located on the boot tray! Cut the long story short, the mechanic chided...
