W weu250 Known Member Senior Member Joined Feb 12, 2004 Messages 68 Points 3,008 Location Subang Jaya (USJ) Jan 21, 2005 #1 To all the Guru's out there....Does anyone know where does the LSD located. I meant where exactly soes it attach itself inside the gearbox
SuPeRtEc88 我係孖8 Senior Member Joined Mar 2, 2004 Messages 1,828 Points 3,148 Location NeVeRlanD Jan 22, 2005 #2 another metal snail stick at output of drive shaft there.........
W weu250 Known Member Senior Member Joined Feb 12, 2004 Messages 68 Points 3,008 Location Subang Jaya (USJ) Jan 22, 2005 #3 thanks SuPeRtEc88....So it is not on the Final drive or anything right..... The thing is my gearbox has problem and I have to overhaul it or change not sure about the damage. So I was thinking would I loose the LSD thank you very much for your input.... :rolleyes:
