K20A fitted on what honda model
mysayasan
83
1,508
Johor Bahru
Which is most suitable honda model available for K20A swap.. and how much it will cost.. i prefer no adjust on the mounting and JPJ approved.. heheh sry nub here.. need help from sifu
joev8796
145
8
many civic can fit tat engine, i've seen on mag a lotus, mrs, eg6, ek oso can fit tat engine
mysayasan
83
1,508
Johor Bahru
eg6 and ek... 1.6 litre right.. can pass JPJ?.... which car dont need to adjust mounting.. which is the cheapest swapping for the car listed
joev8796
145
8
my fren wife's ek9 is using dis k20a from DC5. she din endorse. it's better u get 1.8 civic as da diff on da parts r lesser
klx
63
4
1,508
the increase in cc (from your present cc) should not be more than 30%. So, from 1.6 to 2.0 is OK. Of course gotta make sure its properly fitted etc lah. Go with a reliable workshop. After transplant, make sure inform your insurer coz if accident, they may not recognise it, different engine number.
khoo198
1,948
2,067
N9
mysayasan
83
1,508
Johor Bahru
oo 30%?... not 25% mmm if still ok.. i find a civic wihtout and engine and swap with k20a... how much for swapping and all.. any 1 got quotation for swapping k20a into a civic.. really interested here
lightningfield
2,474
126
3,163
Johor Bahru
www.ef-honda.com
if you plan to do k-swap, EG and EK are the best chassis to do so (lightweight chassis means power to weight ratio is improved). Basically it is plug n play if you use the correct aftermarket mountings like Innovative and Hasport. No modification needed on the chassis. But you must also count in other things to complete the swap: wirings, exhaust system (custom header is needed), shifter box etc..
Hasport Performance
http://www.innovativemounts.com/default.asp
some photos of an EG with K-swap, registered and daily driven.
The Black Mamba: Blissful Evening at Tung Chun Racing
LuKa
618
19
Kedah
Too much power on a heavier n bigger engine inside a light car.. will effect handling department.. prone of understerr will occur on FF car due to weight distribution is being upset... i mean if it is used for the street or track.. for drag, it doest not matter...
mysayasan
83
1,508
Johor Bahru
uhuh mostly for street use..
zac
1,347
231
Johor Bahru
Honda Jazz!!! looked cool when drive slow with proper bodykit ofcos and if ppl cucuk you then you can show them your tail lights and vtec roar~~~ js racing jazz use k24a...
Yong_5290
3,637
49
Klang
hotmail.com
tis is y the new K series is introduced...last time eg o ek put h22a sure understeer kao kao
with k20a and the amazing helical LSD...they r good in straight and also corner as good
AD_EG
6,000 RPM
6,328
231
Ipoh
K swap in EG/EK :love::love::love::love::love::love::love:
if i remember correctly...standby 25k just for parts....excluding installation...might be less...
JDM_YANG
50
20
1,508
i spent about $18,000usd to drop and built my k24 block/k20 head...need more info let me kno..btw i made 305whp 221ftlb on a Kpro on the 2.4 block
affiq
277
24
well...if im not mistaken...if u put a k20 into an eg or ek...be ready to spend around 30k+..not sure if the price has change since the last time i asked...
ddv_nk12
1,228
236
663
PD
price hasnt changed much even a year later. i was just speaking with one of the boys in TC, they said roughly 25k la. could be more but not less. just the engine, gbox and the other parts is already btw 14k to 17k. thats just the parts u buy not including the labour and also other parts like mounting n all. not sure bout ecu if u can use the k20a ecu. not discouraging but its costs a lot.
btw, this is an old thread.
cRazYee
307
63
with rm25k cash, why don't you get just proper DC5 or EP3?
same all hassle, ek9/ek4 isn't cheap either.
Dos and Don'ts of Car Washing:
  • Do not wash your car when the car surface is hot. The soap usually gets dried up rather than reacting and removing dirt.
  • Morning time is a good time to do a carwash as the temperatures are less and no hard sunlight.
  • Pre rinse to remove loose dirt, leaves, or other debris that could scratch the paint if caught under a sponge or towel.
  • Never use a household detergent to wash your car...
