K-Seal. Best leak repair in the world..Proven...
alienfx
36
DON'T WASTE MONEY ON QUICK FIX 'GET YOU HOME PRODUCTS
K-SEAL REALLY IS PERMANENT FOR THE LIFE OF YOUR ENGINE
K-SEAL REPAIR DEMONSTRATION - YouTube
Kseal Save Time & Money
Avoid time consuming and expensive mechanical repairs which could cost you hundreds of pounds.
Kseal Repairs most leaks in the engine block or cooling system
K-Seal is specially formulated to permanently seal most cracks inthe engine block and head. This unique product is guaranteed to mix with all types of glycol based coolant and antifreeze.
K-Seal can also be used to seal holes and cracks in the head gasket, radiator,heater core, freeze plugs, water pump casing and other metal components of the cooling system in both petrol and diesel engines
K-Seal Permanent Coolant Leak Repair.
K-SEAL: HOW TO FIX A HEAD GASKET OR CRACKED BLOCK - YouTube
SMS or PM me to deal. Able to COD in Klang or Pos it.RM90.
alienfx
36
Best gasket head and radiator leak fix in the world..
Can any one custom made BRAKE PUMP BRACKET for satria ?
I have seen brake pump bracket,it seems to be a very simple
bracket but cost more than hunderd bugs.
So i would like to ask any of u can teach me to custom made one ah.
