integra Headcounts!!
integramania
2,336
Bro...if u wanna play low end/drag u better stick with the 4.75....I think comparing the 2 FDs 4.4 will be more comfortable to drive...we you go on highways u won't have that irritating high rev...which if i'm not mistaken will suck up fuel more than a 4.4....
In terms of stifness is ur Spoon absorbers very stiff? Coz usually its the suspension that makes it stiff....as for bushings, it may play a part as well....how did the car feel prior to the bushings?
As for tire size, if can better to stick to the correct size, and if u go for 15' or 16' better use 205... with 16' you can go max 50 series i think....60 or 65 series i doubt will fit...looks weird too...even 55 may look big...can ur wheel arches clear this size as I presume your car is also lowered...
LuKa
618
19
Kedah
Re: integra Headcounts!!
for ek sedan u need to add the rear ARB for better handling... ek sedan does not hv good handling compare to the 2dr version and eg models... it tends to slide away from control as too much weight or body roll which result in understeer at most...
Also cannot compare EK sedan with DC2 even diameter lenght n height is similar... the dc2 and eg are more similar and suspension are interchangeable too...
cad843
403
12
Oita Ken
I almost forgot bout the tyre clearence ... but still can play a bit with adj upper arm ... if not mistaken -0.23 toe will be the best setup but still need to adjust bit on my spoon height ... but yes ... I will try and test which tyre can make the best clearence for 16" rims ok ek
As for the bushings ... maybe u can try change main bushing at ur rear lower arm .. but I prefer to change the whole set ... including front one.
---------- Post added at 09:38 PM ---------- 6 hour anti-bump limit - Previous post was at 08:36 PM ----------
Yes ur correct, there's 1 time when I almost spin my car after overtake 1 bus somewhere air keroh ... luckily notting happen ... just my rear anti roll bar break into 2 piece and i'm using brand TNB which is quite big compare to the stock one. Until today I also dunno how that ARB can break into 2 piece ... thats why im seeking an advise from all sifus here ... pls let me know any secret set up ... I know this hot issue always been discuss during TT isnt it ... heheheh :biggrin:
ganoalvin
24
Hey guys, im also a da integra owner.Nice to meet you all.
mindef
576
Danny, totally agreed...lama x rempit, vtec oledi karat....
bro set ur A/F 1st b4 u go rempit :listen:
danny oredi vtec b20b ka? :adore::adore::adore:
like this kennot kejar u guys lah... semua power2 3rd gear i bau u punye asap vtec jantan
:banghead::banghead::banghead:
---------- Post added at 04:34 AM ---------- 6 hour anti-bump limit - Previous post was at 04:24 AM ----------
sounds good bro...when?
how bout sat evening we go bagan makan seafood :eating::eating::eating:
we use klia route n let our vtec scream all the way n make sure u guys bring ear plug :laugh::laugh::laugh:
integramania
2,336
this Sat cannot bro....also i think if can go for a short morning trip better....easier to drive...
eh my check engine light come out...checked and it says its the knock sensor....any ideas? Kenny told me just try changing the knock sensor....
cswong
25
Rin, saya rasa kita pergi tt dekat dekat aja la....call u esok..
mindef
576
if check light come out its easy to troubleshoot by urself... u can jump pin to the socket n the code will tell the problem...
---------- Post added at 12:29 AM ---------- 6 hour anti-bump limit - Previous post was at 12:26 AM ----------
u punye kereta manyak laju haa sekang...
semua kete mau cucuk :adore::adore::adore:
mindef
576
Yeah...I did....and it says Knock Sensor Error.....so wat to do? Must change?
yes sensor kong edi...
any idea whats the market value for da6 in a stock condition? and fully modded 2xx+ whp/2xkgm?:hmmmm::hmmmm::hmmmm:
eddyann
28
anyone of u experience using tufoil in B18C? i'm considering to pour them in hoping the engine sound will be quieter abit. sometimes my engine sounds like a diesel during idle. no misfiring though. is this the infamous tappet sound?
eddyann
28
bro either tappets or the vtec bullets....i dunno wats its proper name la...but it sure look like bullets...
vtec bullet= vtec solenoid? the one with small cylinder shape like a magic hat? if teppet how to make it silent? i plan to change the internal parts to a new one if i can make the teppet (if teppet is the case) sounds quieter.
Similar threads   Forum
  Similar Threads
Hey guys, Need help!
REWARD
RM5,000.00
For the recovery of
Ford TX3 WHITE
WDD 69
Missing from area of Aman Suria, July 29, 2009
In full condition with
-One unit WACOM Computer Monitor
-One unit Projector
RM3,000.00
If recovered incomplete or without the above items
Call/telephone
Mr Lee at:
016 323 5443
Standard Stock WHITE TX3, White Rims, no funky stickers, new paint job, new tyres -WDD69-
Cheers mate,
LEE...
