i have a problem that want tips of kampung style tuning. dun say dyno tuning or wide band tuning or aftermarket knock sensing becos i'm in kelantan and to go KL...huuhuu far far away lah
my ride is kancil 850EX that being hybrid with L2 turbo, piston change to L2 and so on so on (check my website for further specs information)
CHECK OUT MY WEBSITE HERE
my problem starts when i change to GSR turbo injectors (390cc) from my ori L2 injectors (190-200cc). the problem is knocking/pinging.
i set the safc and test it myself...no monitoring system just my EGT meter that shows lower temp than before (i assume i running rich a little) even on 4000rpm and higher. my engine starts knocking when i suddenly WOT after cruising at 3000rpm. sometimes 5000rpm also have knock.
now i'm confuse becos after changing the injector...no adjustment made to distributor.
now, should i retard the ignition timing through distributor or any other method of tuning kampung style ?
thanks
p/s: i afraid if i retard the ignition timing, my power fall off too much
thanks
