help me with 4g91 DOCH
V8_nutter
516
miemook said:
allo... ko dah tukar throttle body ke blom? klau blom try kalai EVO1/EVO2
punya. pastu piping 2'. Gearbox kasi rojak masuk adj cam pully + feul regulator SARD, pastu gi setting (ipoh aku tak tau tp kat shah alam aku tau) ... nzk lg laju tukar pisto. try buat semua tu mesti keta kau best giler (utk N/A).
Change throttle body evo1 or evo2, what milimeters is that ? Then gearbox rojak, what gearbox to use ? Please explain to me more about this.
syahizad
52
boyzone said:
ISC is the stepper motor which is to control and compensate air input to smoothness on idling speed, increase idling when air con is switch on..etc.
location below throttle body. with brown colour motor, test with ohm meter, u can get 30 ohm for each terminal. if come with black colour head ( like GTI/ Putral using ) u can get 40ohm at each terminal.
TPS is throttle position sensor, locate at infront of throttle body. check with voltmeter on pin 1 and 2, with normal idling speed, u can get it around 550mV to 950mV.
If not sure, better send to workshop for checking.
Good luck :D
thanks.. the problem solved.
i find good mechanic. good one la... something wrong with meter sensor.. dont know.but its worked.
I need to re-confirmation from cross drilled disc sifu..
Is this the correct direction the disc suppose to be ?? I am referring to those "curve" on disc since terbalik L and R side also can fit one :unsure:
Some said suppose to "follow" the wheel rotation but some told me need to terbalik
LEFT HAND
RIGHT HAND
Pls englighten me
