owh you have prob with the wiring.... the check light & engine running in safe mode...thankz for ur advice..im going to drive by wire...next week start project...send my car at millennium sunway...
huumm.... for injector just like jo1 said, just measure yr current injector resistance & go buy resistor at electronic store. than put it yr current wiring...
for the ignition coil... cannot use resistor?? i oso dun have experience doing this.... but can try lah.. just measure yr current primary coil resistance & put it in wiring... humm, i don't know if it will generate more heat & fail the resistance.... need to ask electronic engineer first lah before anything bad happen. Or other method is try buy one unit of coil & plug all hole for spark plug wire contact ( secondary coil) .. the coil will act like dump coil... just to cheat the ecu.. dunno it will work or not, can try coz it more safe...
but i think campro use map sensor right... not airflow ....
