hattech-v said:
no 1. wrong answer...
no 2... its possible... but do u think it can cause such damage?
Hmm.. why no. 1 is sure to be wrong? With the cylinder liner cracked, the water already mixed with water from the coolant.. so it it easy say for sure? Hydrolock can break rods, so why not break pistons?
As for no. 2... B18cr is a high compression engine, so the max pressure building up during the power stroke might just be enough.
It doesn't seem as if the valves hit the piston face (hardly any scratches... and unless he used non-stock piston and cams..
Still, a lot of other factors do make it seem like an interesting case..
What broke the valves? The piston have holes in the middle, and it doesn't seem to be caused by the valves.
Another reason is that something got into the combustion chamber.. but not likely to happened after driving for a few kms! The first start-up would have shown the problem immediately. Or was the car running ITBs/filterless?
Sucking in a small, hard material (metal/stone) would likely break one valve leaving the other valves intact, cause excess pressure in the combustion chamber, cause the holes (I don't think they're from the plug since they don't align with the plug loc.) and somehow crack the sides of the piston and the cylinder liner... but you'd be the one to know for sure.
Since this seems most plausible (at least to my non-mechanic mind),,, I think something got in, jammed itself on the valve seats, valve (the flat/convex part) returns to seat, sits improperly or bent or broke off, got hit by piston, valve part the broke of dances a while in the combustion and compression area, causing more damage.
Still it would mean loss of pressure, and it's hard to crack a cyclinder liner without pressure.. but the valve edges are quite sharp and powerful when they're bouncing around in the cylinder, so that might even be enough to crack the cylinder liner.. though I'm really just speculating here.
I'm stumped as well.. let me know what's the result.. I'm curious as well.
