Can you list down amp power rate at 8ohm.. coz I never seen before.. normal amp rate I can see in our market is 75wrms X 4 4ohm, 150wrms X 4 2ohm, 100wrms X 1 4ohm, 200wrms X 1 2ohm, 400wrms X 1 1ohm, 800wrms X 1 0.5ohm.. everything from 4ohm & down to 0.5ohm.. I'm refer to amp damping factor... every amp have damping factor & writing in manual.. some maybe 6.5 at 4ohm, 8 at 4ohm, 4 at 4ohm...Kippo said:oldskolboyz,
damping factor will affect sub response if its value it damn small. Valve amp has generally low damping factor. But above minimum damping factor where you cannot hear the difference between 100 & 150 damping factor, who gives a damn about running the amp at 1ohm or 2ohm or even 0.5ohm.
and its start getting funny when ppl say better run at 8ohm for better control due to damping factor not affected.
I should stop here... To be hornest & professional.. we not in same leage.. I'm talking about Proton Car... You talking about Modenas motor.. if Naza car or Perodua still can consider but to far away..Kippo said:oldskool,
u never seen amp specs. in 8 ohm? are u sure? home amp? hi-fi amp? they all rated at 8ohm.
and damping factor or 6.5?!?! are u sure u r looking at the right figure. coz' damping factor usually in values of 50s and higher. Valve amp has lower values. But 6.5 or 8 are doubtful.
