charade aura brake booster
viko5805
234
i need help here.....if i want to change my brake booster for charade aura g100.....
any other booster that i can change...???
i cant even do emergency brake....its very dangerous....
my fren say if i change the booster will be more better...
is that true...???
thanks............
cb70
262
Serdang
Any leakage at the booster bro? I've experienced that before...I'm not sure whether other booster can fit in.....
viko5805
234
no.....no leakage.....
so how....????ur booster got leakage lar..???
beside change booster...what else can i do..???
change rear brake to disc brake...????
thanks bro......
cb70
262
Serdang
viko5805,
sorry i confuse btwn brake booster & pump, previously my brake pump kong not brake booster :") ...From what i read, the 'check valve' at the booster is function to allows air to be sucked out of the vacuum booster. If the engine is turned off, or if a leak forms in a vacuum hose, the check valve makes sure that air does not enter the vacuum booster...I think mybe got problem, maybe the hose leak...
just my 1 cents ..hehe
TiBuN
482
Penang / BM
Oh, in that case, my old Aura is brake pump kong, the oil leak from the pump... So I guess different case, the earlier symptoms I got from this leak is spongy braking system, can keep stepping further and further in (even with the brake level max).
Changed to the Deto pump + booster, everything solved.
viko5805
234
ok bro........
thanks......
i try......
btw.....if i want to change aura rear brake to disc brake....
what kind of disc brake can fit aura ....
cheerzzZZzzzz.........
cb70
262
Serdang
or some says can also fit detomaso rear disc brake..rite guys ?correct me if im wrong
TiBuN
482
Penang / BM
g100s said:
u can use the aura 1.3 disk or the GTti(da turbo version)
Aura 1.3 tak da rear disk brake. Can use GTti or Detomaso disk brake, the later is easier to find in half cut.
viko5805
234
normally how much that cost..??
brake pump+booster, and rear dics brake...???
harithnorman
13
bangi
I buy from half-cut, complete rear disk gtti + rear absober gtti for rm500.00.
i think gtti rear disk is hard to find, better look for detomaso rear disk.
gavan
1,408
4
Shah Alam
ergh, i got detomaso front disc brake laa....extra set, never used before..half cut condition....its vantilated not like the original aura disc which is solid disc....
and the rear can use GTti or detomaso, doesnt matter, can fit...front for aura oni can fit GTti disc and the detomaso front disc oni can fit into espri or ascend.. =)
TiBuN
482
Penang / BM
I asked a mech here in Penang and he said he had modify before Detomaso front disc to fit an Aura before, it works but in the long run got reliability problem like some odd noise coming out due to the modification. Either his material used is not good enough or the assembly work is shabby, but either way, if you really want, I believe a good workshop it should be able to fix.
<removed>
Police report had been made.
i think better close thread before owner find this thread and cause trouble with me.:creep:
