Can GSR air flow 449 replaced mirage OEM Air Flow?
merz2
116
Malaysia
Can GSR air flow 449 replaced mirage 61t OEM Air Flow? if can, i want to know is it any parts of the engine must be upgrade...like injectors or fueling system to match it? currently now im using bosch fuel pump for fueling and already change the turbine to TD04L twinblade from GSR...any sifus here plz give some advice or guide...:smile:
khoyos
2,632
156
5,163
Shah Alam
can, but there will be no performance increase. better use VR4 airflow and match with vr4 200 ecu (code 8618).
or evo airflow match with evo 510cc injector.
put bigger cc airflow will cause lean mixture.
i matched vr4 airflow with vr4 ecu running TD04L turbo on stock 4G61T. can really feel the difference.
after getting bored, i tried evo 609 airflow, evo injector, TD05-16G still with stock 61T block & head, boosting 1.2 bar. hehehe damn nice. sedap.
now still running the setup. wait till i have money to go "curi ayam" use vr4 block.
here's my 4G61T engine pic. pure 1.6 dude, no cheating vr4 block underneath.
jinkl
4,624
376
3,183
sure or not tak curi ayam
i heard inside the block got high compression e3 pistons
khoyos
2,632
156
5,163
Shah Alam
not yet la bro, i'm still waiting for your pistons laa...
speedz1665
612
Power Power Power.....lolzzz
merz2
116
Malaysia
actually my idling not stable...its turn up and down like using high cam...some foreman at my hood said oem 61t air flow sensor not have accurate reading...so i was thinking maybe GSR air flow can fix this problem..not really target for performance....just a lil' bit geli-geli okay laaa....:) any possibility GSR air flow can match with 61t ecu or injector without lean...?
merz2
116
Malaysia
ooo throttle body...ill check later..i thought this prob is all bout air flow...
merz2
116
Malaysia
dont want 61t la... want to put gsr airflow in 61t....
Hey Guys,
I planning to do a open pod filter in my iswara (4G13 carburetor). The iswara is built with a drop in filter. So my question is that
a) what parts are require to fix an open pod filter
b) do i need a heatshield if i'm planning to make a cold air intake
c) where is the most reliable place in KL
