hahaha...at first i really thought that joeker sell aluminium pipe's.
joeker,dosen't s.steel soak up more heat compare to aluminium?
from what i've know,s.steel is bad choice for i/c piping compare
to aluminium.is just that aluminium cost much more then s.steel.
that's why alot of ppl opted to use the next best thing,s.steel.
just my 2 cent.
its not easy to weld ALU.. cost depend on type.. 1xxx or 5xxx series.. SS more harder n tough than ALU.. ALU easily to crack compared to SS.. but ALU is lighter than SS..
My car is Civic EK3
The problem is got abnormal sound at from arm then
1. At 1st, I changed all ball joint and the noise still same
2. Few months later, I changes upper arm bush and the sound reduced 50%
3. Few months later, I change lower arm bush and the car run steady with new bush but the problem is the noise increased
what will the problem be?it is
1. Absorber??? --->my absorber no leaking or the absorber bush damaged??? --->is this bush sold in market?
2. Absorber shaft...
