4G93P Engine Block for SALE!
seisuichai
147
Taman Mayang
sorry..newbie here....engine block means what? whole engine ah? can masuk iswara or not? what else need to add or change ah? gears everything all leh?
KryPToN
809
Selangor
errmm... engine block is the lower part of the engine (housing the pistons, conrods, crank shaft, basiclly the combustion chamber area). engine head is the upper part.(valves, cams, etc). Iswara.... im not too sure. Shouldnt be a problem i guess cause ive seen saga's with vr4... so, you need to find yourself another matching engine head and gearbox.
seisuichai
147
Taman Mayang
thanks for the info man.really appreciate it...so basically the engine is divided into 2 lah issit? engine head and engine block?
KryPToN
809
Selangor
yupz... thats the 2 main parts. Dont forget the other small small items that are also required for an engine to function such as throttle body, intake manifold, alternator, fuel injectors, fuel pressure regulator and etc etc.
KryPToN
809
Selangor
pictures uploaded...
just removed it 2 days ago...
(all items like pistons, conrods, bearings, crank shaft are not removed and is included)
my car is satria..if i wan change hks adjustable, evo 1,2,3 izit can use for my car?thx for all sifu help..
