one set of r3 stage3 hi cam cost how much? 2.4k really can get all the things done? that is the good deal man. i saw r3 street cam in eneos in 1 u, 1600, wa lau... very nice la cam, but price also very nice
r3 stage 3 hi cam is designed for track racing if i am not mistaken... which means u must keep ur engine at high rev all the time to squeeze out the power. so bro u must decide where u pek ur car kau kau most of the time, if u just like to test a bit on normal jalans, then better get lower stage cams to actually make ur cars "faster" in terms of real situation cos u can not drive on a normal like ina track, further more the stage 3 cam are for 1.8 engines, which has much stronger torgue at low end. so the possible thing is that before ur car power kick in, somebody is already in front, and with the 2 to 3 thousand rpm u may not be really catching up the front car. then shift gear, if the rpm drop out of the power band, then ur car sluggish again, therefore u must consider ur gb ratio, ur clutch as well when u wanna put this stage 3 high cam. but if u are track kaki then go for it la, surely give u much better performance. with pnp, high cam, and cam pully, u may get around 12 to 15 hp gain.
it is better that u at least get a e - manage to make sure that ur cams work well with the fuel and ignition timing. mod on fuel supply may be needed as well, as standard injectors may not be strong enough for ur power desire.:_: of cos u can do all this slowly la... if u get all these done, maybe can get around 22 to 25 hp... that is a lot for a n/a car with no mivec or vtec already. of cos, in order to achieve this, u have spend a lot as well, and pay a lot of maintain fees, problem solving fees, and fuel fees :cyclops:
so bro, ur money your car. so think of it carefully and choose ur mod... and tell us how the r3 cams perform if u really install them. i am quite interested. but not stage 3 la,no money pay petrol, i want stage 1 super street cam only. hehe:shades_smile:
