4age 20v - 4 throttles
chloe111
24
guys,
how does the 4age 20v 4 throttles work?
at what rpm or what condition will all the throttle fully open ?
and how does each throttle synchconize open at what rpm range..
sort of curious la.. cos normal single throttle car the concept very easy and clear..
but 4 throttles.. i blur.. pls sifu explain a little bit for me... can??
:_: :_: :_:
cuscostrutbrace
987
62
3,028
chloe111 said:
guys,
:_: :_: :_:
Very simple,when u press the accelerator pedal,a cable connecting your pedal to the throttle linkage and opens your throttle,all 4 of them are open at the same time,you press more,it opens more,you lift off,it closes,even if did not start the engine(rpm = 0),it also opens if you step on the pedal,each throttle is interconnected to each other at the same axis.
gogogo
341
sorry for the intterrupe. may i know how offen we need to service the four throttle, what type of service needed, if not service what deffect will happen and the cost of the service as well if posible. thanks.
gogogo
341
any advice/info?:embaressed_smile:
yolk
1,144
PJ
meaning is it's purely mechanical .. u step on accelerator and the ITB will open according to how much you step ... doesn't matter if your engine is started or not ..
First of all, thank you for coming in.
Please share;
1) What spark plug brand you are using?
2) What is the code?
3) Fuel pressure?
4) Injectors?
5) Fuel pump?
6) Boost pressure?
Today, i downgraded from Denso Iridium IK24~heat 8 to NGK BKR6E-11~heat 6 (standard)~ I am so affraid to boost although with standard pressure~ :adore: Consider everything stock standard~ I'll post pictures of the new spark plug installed after a few runs soon~ :bawling:
Please help~ :bawling:
