sumimasen
1,220
9
we are asking whats ur current spec lor...
yes, as he is being so secretive, so why i need to reveal my "secretive" info..do it your way lor..ciao..
sumimasen
1,220
9
atlanta short block running dry sump which capable 10000rpm..perhaps?
since u r going for 11000rpm...what kind of preparation hv u done to overcome oil starvation?.. hi rpm need serious engine build up.. so seriuosly, i wont touch about ur secretive thingy, jz gv us some clue bout my question..a lil bit oni oso can lar.. teaser..
Bern_91
12
wah~ bro~ newbie here yar~ can reach 11k den from from 8k to 11k still have torque? woah~ erm~ can listed abit wad u modd? ^^
yr secretive din listed nvm~ i mean any PNP item~
sa320w
16
semporna/sabah
actually, i got this ingredient from a fren of mine who have a lot of experience during his time at peninsular...actually its a usual modding...we all kno many racing parts around..it including crankshaft,piston and so on..besides,u may also make some modified to your head..after u PnP, u must aslo put a high performance part in order to make the head is ready for any hi rpm situation..
for the question regarding on hi rpm..yes..its still have a tarque..and the engine still want to push but i did not force it..
---------- Post added at 10:25 AM ---------- 6 hour anti-bump limit - Previous post was at 10:24 AM ----------
come on...share your experience...
tofu_manic
1,342
91
5,148
wat carb u using now...something like a 295, u need twin carburettors to match
friend, sorry to say, if u wanna rev to the moon, lengthening the stroke of the crank is not the way to do it
not saying stroking is not good; stroking the engine will definitely add some ponies its just that u seem to want mega rpms
by nature, shorter stroke engines are able to rev higher while longer strokes make more power earlier
engine still wanna push at that high rpm according to u, but that does not mean that u are faster than IF u shift gear earlier
may i noe, lets say if ure at 9000 rpm in first what rpm does it hit when u shift to 2nd
l
sa320w
16
semporna/sabah
i kno wat are u trying to tell me bro..
first i wuld like to tell u that im using 295 carb...
i kno wat im saying is hard to believe rite??
actually, our first research is using normal carburetor..
and that engine is not modded yet...
and rpm is up until 13k..but no power...
and then me n my fren try to make it better..
we decide to modded one engine..
and finaaly we have succeed to make it more3 powerful..
but the problem is the rpm is only can reach 9k but when the car is stop..
it can reach until 11k..thats y i entered this forum..to get some idea grom all of u..
regarding on the shift to 2nd..when i blast my engine until 9.5k..it will down only to 7k when i shift the gear..
and the power is also not decrease..i also have a brain bro..i dont do it if the tarque is drop down in 11k..
---------- Post added at 05:16 PM ---------- 6 hour anti-bump limit - Previous post was at 05:15 PM ----------
to tofu manic..
so what are the solution do you have??
tofu_manic
1,342
91
5,148
no no what i mean is that for u to make full use of cams with such duration, u need twin carburettors; single carbs are limited in the amount of fuel/air it is able to supply
plus what im saying is that if u want more power at higher rpms than b4, stroker kits are not the way to do it....the longer the crank stroke, by nature it will bring down the rpm at which peak HP occurs
may i noe what are the speeds u achieve with 1st. 2nd, and 3rd gear, interested to noe what speeds u achieve with 9000 rpm, im NOT saying u cant do it, im just interested to noe what can be achieved with this engine
my solution ar....for maximum high rpm is getting twin carbs, crazy cams, oversized pistons, pnp head, 4g18 pistons and custom longer length conrods which u would have to order, this by nature will make the rod ratio more ideal and suitable for higher revs, dont forget high compression and improve sparking, ok lah dats it
sa320w
16
semporna/sabah
tanks bro for your advice..
if have done all that u said just know..
for ur information..i have used wabber for my car.
but the problem when i using this..i cannot entered 1.5 sinlge cam category..
i have to entered 4g91 category...
the K/M meter shows if mistaken on 3rd gear is near 170...
---------- Post added at 12:20 AM ---------- 6 hour anti-bump limit - Previous post was at 12:09 AM ----------
besides..the carb dat i use is not a usual one..
i also modified it to assure my carb able to supply sufficient air/fuel..
the jetting of that carb is also modified..so dat it can supply enough of air/fuel...
sa320w
16
semporna/sabah
sa320w
why want to rev so high? why not just change gear.
Lol this dude is hilarious
never mind...
u don kno wat i want...
for ur information,if u want to play 4g15..1.3 gearbox is a good one..
if u dont believe me..ask someone in this forum..
and i finally get da solution for all this things...
tanks for all the person dat help me directly and indirectly in this forum..
especially to tofu manic...he always give me a good idea....
tanks bro...
Silverstein
28
2
1,503
lol, is a "Common knowledge" that 1.3 is a short gear ratio.
doesnt take much digging or research. Common sense explains why is it shorter gear ratio.
anyways, good luck to you, i dont think you know what your doing though.
sumimasen
1,220
9
sa320w,
what is the final drive size for 4g13 gbox? (we use kampung style la, how many teeth?)
does 4g13 8v and 12v gbox carry the same construction?
n again, what is ur current compression?
damone
500
5
Hey guys. Help me up abit here aite.
Recently my satria 1.3 SVDO has been very sluggish in terms of acceleration and pick up wise. In other words, it feels laggy and no instant throttle response.
I am listing down the list of modifications I have done to the car. BTW it got worse after the exhaust and LCP.
1)Performance drop in
2) 4-2-1 extractor from W.Heng.
3)1.7 inch outer diameter piping following original route, one mid bullet and a big tabung straight flow exhaust OEM style.
4) Engine oil 15w50 from Mobil, change every 5000k. Sparkies are normal OEM, plug cable OEM, I think are in good shape.
5) Undampened lightened crank pulley. (this is where I feel that it is sluggish the most). No instant throttle response.
I installed a vacuum meter, and I realize, that when I am idling, and when the AC compressor kicks in, the vacuum needle does not stay still, instead it kinda jumps back and forth. I can feel the engine slightly revving, like it is on high cams. So lets say if the AC kicks in, and the needle shows a reading of 15, then it will hover between 14 and 16 slightly and the engine revs a little, like I said, being on high cams.
I am not sure of what makes my car really sluggish also, unless someone can recommend me a good mechanic around Port Dickson, or Sunway and Subang area to diagnose my problem.
Thanks.
PocketRocket
'(00) Mod'er
11,388
953
Up Yours
maybe ur engine oil is too heavy.... normally a 10W40 is good enough. want it lighter abit more u can change to a lightened crank pulley if all else u wanna maintain standard..IMO
He may have made his name flogging modern AWD, turbocharged rally-prepped machinery around gymkhana courses, but even Ken Block couldn’t resist leaving his AWD 600+hp rally-spec Ford Fiesta at home to hoon about in a classic Ford Escort Mk II with a Cosworth mill under the hood in the woods of upstate New York.
The Escort was introduced to...
