UK Mintex brake pad
UK Mintex brake pad
xbalance2002
1,501
349
1,683
Mintex uses a unique pad formulation which provides a high level of friction yet is engineered for long life, rotor friendly and low dust (little to no evidence of material deposit on rotors). The pads require less bedding distance and offer reduced noise. Excellent O.E. replacement pads and are ‘E’ marked, meaning they meet or exceed O.E. specifications.
Contact: 012-9779338 / PM
Price: PM for your car model
viostar
475
2
PM price for wira 1.6 front & rear pad..
TQ
Guys
I just had my alternator replaced. After that, I see my idle rpm is very low, around 500 (before this ok, around 1k). During alternator installation, I see the mechanic remove both terminals of the battery too.
Is it because of the ECU being reset? How to get it to normal idle rpm? Should I go to workshop, spend RM50 for them to properly set my ECU back (using that device which they plugged in it under the dashboard, I duno the name :confused:)? Appreciate all inputs. Thanks.
