http://www.zerotohundred.com/newfor...2-point-front-engine-bar-for-proton-wira.html
USED Ultra-Racing room bar & 2 point front engine bar. For Proton Wira.
i heard that Powerzone are regrind cams.. so resulting in lower lift... ..
i the workmanship ok den nvm lar... if not, the welded part chips off den die lor....well.. performance cams have longer valve lift duration... that means the valves are opening for a longer time and the overlap is more... in other words... intake opens earlier and closes later.. same goes to the exhaust...
to do that, we need to cut off some parts of the cam lobe for the long duration profile... i have heard that some parts of the cam lobe will be welded for more meat and then reprofiled...
did u lightened ur flywheel as well??...hi,any1 can help to answer my question?
my cars is wira se manual, 1.6 flywheel,K&N filter, ssr rim, normal muffler and other just stock,
if i wan to bolt on turbo (0.4~0.6bar), and unichip,
what else should i mod??
cause now 1~2 gear the pick up still satisfied,but 3~4 gear is very slow,
run in kesas highway, cant even let go a van( new toyota high ace),
so planning 2 bolt on turbo,
but worried about the fc and the problem after bolt,
sure ur fc gonna be higher then stock bro.that is a common thing that need to behi,any1 can help to answer my question?
but worried about the fc and the problem after bolt,/QUOTE]
after using the 1.6 flywheel can u really feel the different ?
after using the 1.6 flywheel on ur SE , can u really feel the different on ur pick up ? am using the same car as u ?hi,any1 can help to answer my question?
