Perdana V6 Community Forum *
kimix
Mar 29, 2017
25
Klang/Selangor
I m driving a 17 yrs old PV6.....
Is it advisible to use lighter grade engine oil like 5w/30,10w/30 or 15w/30?.....
Will these grades be too light for this engine?
Does the engine consume engine oil at the moment. Using 30 weight oil is not a problem and it all depends on your engine. For example my VR runs on hydraulic lifters and tried using 5w30 once. On cold start is nice, but once warmed up the lifters becomes very noisy. Using 5w40 is much more quiet so I switch back to 40 weight.... :driver:
kimix
Mar 29, 2017
25
Klang/Selangor
Bought used Toyota Denso FICD....see if it helps on my "retarded " timing
Has anyone used Liqui Moly 5w/40....is the oil OK?,...
The Marketplace Top Posts
any 1 can advise engine to swap into an Opel?
it's a FF , did read from foreign site, sr-20 , 3s-gte can go in.
but not sure wht did they done on the enjin
any 1 experience this or ur tuner modd and Calibra b4? kindly advise, thank you
