Perdana V6 Community Forum *
kimix
Mar 29, 2017
25
Klang/Selangor
I m driving a 17 yrs old PV6.....
Is it advisible to use lighter grade engine oil like 5w/30,10w/30 or 15w/30?.....
Will these grades be too light for this engine?
Does the engine consume engine oil at the moment. Using 30 weight oil is not a problem and it all depends on your engine. For example my VR runs on hydraulic lifters and tried using 5w30 once. On cold start is nice, but once warmed up the lifters becomes very noisy. Using 5w40 is much more quiet so I switch back to 40 weight.... :driver:
kimix
Mar 29, 2017
25
Klang/Selangor
Bought used Toyota Denso FICD....see if it helps on my "retarded " timing
Has anyone used Liqui Moly 5w/40....is the oil OK?,...
The Marketplace Top Posts
Hello there,
Just wanna ask some help here...
Before this i used GReedy manual TT and already swap with Full auto Blitz MSTT.
The timer installation is quite simple although the color code(wire) is differ between the two brands. as long u know where to connectlar..
The timer function is done.Here comes the tricky part.
Where to connect the speed sensor? Based on apexi RSM manual installation (Blitz official website don hv), i just tap it from ecu speed signal. but not working lar. Some say...
