Can new Wira 1.6l (M) gearbox still be found?
7,514
hahahahaha...new gearbox for rm2k???
:rofl:
joking rite....
halfcut gearbox for wira/satria 1.6 costing around rm2.5k woooooooo
if just synchro....replace the synchro will be good enough...many sparepart does have synchro for proton/mitsu gearbox....dun worry
ixeo
4,788
3,080
KL, Malaysia
That's what I was thinking. *NEW* gearbox for RM2000?
Change your mechanic. FAST. Fucker trying to pull a fast one on you.
ken yeang
6,618
1,327
The mechanic probably gonna use diesel and clean bersih bersih the exterior of a used GB, and claim it as new GB to the customer....$$$ masuk poket
30,002
That is why I always tell my friends, sure is recon or just rewashed.......at least recon means the internal have been changed.....:driver:
ken yeang
6,618
1,327
hahaha!!!
rewash GB as recon unit? surely gonna con ppl off their money...
Progen
11
Do you mean new synchro gears or reconditioned ones? The main gears are fine. Clutch is fine too. No slippage or funny sounds / feel once engaged so if I can get new or reconditioned ones in good condition, then I suppose I should be able to use the car for another 5 years or so. Right now it's a bit of a chore to drive since I use engine braking a lot as well and have to change my shifting style to avoid those 'bad' gears which then again happens to be almost all.
ken yeang
6,618
1,327
if the gear box open up oredi, might as well replaced the worn/rosak ones with new items..
Some cases, mech could even do preventive repair....when there is signs of wear and tear.....before actual breakdown occurs..
Progen
11
Ok, sorry if this sounds stupid but what you guys are saying is that it's possible to find NEW synchromesh gears because if that's the case, then I'll definitely get them replaced as soon as possible because the main gears are fine. Just the synchromesh ones are not.
7,514
new synchro yes readily available in major sparepart shop
7,514
Wira common can get, you think VR one can get, because last time mine I bought 2nd hand GB and transfer over.....:bawling:
evo gearbox also nowadays hard to find....the 1-2-3 ratio very nice....especially coupled with gsr 4th-5th...
A Post Every 5 Mins
hey guys, im like totally new here, well just wanna have some ideas, i got my new wira, but i thought of getting a new exhaust or muffler, well thought u guys can help out and suggest some pics, i dont know which exhaust will look nice. =/ stock proton but added a lil of skirting, black paint job =)
Bump:
