This ATF cooler thing is it same like what some of those old school car fellows mod on outside their front bumper? They put some sort of cooler externally with two wires attached. I think that is an oil cooler?All autos have some form of cooler or rather la. Protons all use one single thin ass copper tubing as a cooler. People bypass that and use their full-on coolers which makes more sense. The Sylphy on the other hand is unique, damn ATF line is linked to the radiator water line which makes is quite hard to bypass.
You serious? Come I show you how to over heat a gearbox. No need overly aggressive driving, just downhill Genting is enough already. I've overheated my ex-auto dozens of times. Only managed to resolve it with a cooler + DOT5.1.
Apa sifu sifu business?
A full complete flush in the Persona / Wiras case is about 4L (x2 if you want to flush it). If you're just dropping-and-topping the oil, it's about 2L only. Yes, if you drop the oil, about 2L stays in the torque convertor. So best to flush la and always change the ATF filter.
Genting, I've only been there twice. The last time I go was like during 2004 or 2003.
The clutches will wear, the atf will get dirty, that is why needs to change the atf....
---------- Post added at 09:17 AM ---------- 6 hour anti-bump limit - Previous post was at 09:16 AM ----------
Ha! Ha! Dot 5.1 means your brakes boiled up too?.....
Tiggo ATF, drop and top still need 3.5L
Even though clutches will wear, we still can hear most people say things like maintenance for manual transmission is cheaper than auto. Any reason behind this?
