How to pepper spray?
can hold for at least 30secs, is enuf, at least din breathe in much of those spray residue,wakaka...
seriously, i think they should really educate the user before selling them...
Not that hazardous but my friend use it as a keychain.
Accidentally sprayed to my friend's eye, tear like sh*t and eye red as fu*k.
HAHAHA
Large canisters have farther spray distance but bulkier and harder to carry around. The Safety Demo I attended were also selling various types of pepper sprays. There is one which you hook to your key chain like normal but this one has a holster from which you can pull out the canister (like pulling out a gun from its holster) -- good in situations where your car key is in the ignition and you need to use the spray, so there's no need to turn off the car engine, take out the keys, then use spray.
They were also selling practice canisters which carried only water for training purposes -- RM15. Good to get used to the pepper canister prior to combat!
Put in handbag, mix with other things, so accidentally activated it....:banghead:
Putting in a handbag doesn't serve a purpose that she carries a pepper spray, imagine if it is not kazukimy and is actually a rapist or sex maniac in the lift with her, by the time find her pepper spray in the handbag which is ladies handbag is actually worse than the Doraemon pocket where things are harder to find, she had no chance at all to use it.
Should be in her hand at all times when walking or out of office.
From what i was told, the smell is so bad that you will stray away and have wet eyes and hard to breathe.
I dare not try it at all. Description already can feel how sore will it be if kena direct.
Yup, true. Most cases are when going to and from office/home or your car, so should be holding it rather still leaving in the handbag.
For me, I don't have pepper spray but i hold my car key like a wolverine claw as a precaution
for self-defense.
I told my female friends before as well, if no pepperspray, at least hold your car keys with
the sharp point between your fingers.
for self-defense.
I do that too, but depends on your car keys shape.....
Personally I always kept a small pepper spray inside my glove compartment but its way to small for its own good. If I could have 'Bear' spec pepper spray is even better - more lethal and can spray up to 30ft away with much higher heat ratings but its quite expensive.
haha anyways i dont own a keyless-go car.....i wish but dont think can afford..
Just a note to pepper spray users, those keychain types have very small pressure inside or something along those lines. Over time they will become weaker or the spray mechanism will become weak and eventually that bottle will only be good for droplets, not spraying. So monitor and maintain your sprays properly. The best type is those pressurized spray can types. They last longer and spray range is more.
hm..make sense...so gotta try it once in a while huh..go out on the street and find colour wolf to test haha
The first few bursts sprayed a cloud of gas...just make sure the wind is not against you...PWNED sendiri...LOL
A thread every 60 seconds
