Tire Price list Zth
mahihi
110
helo every1,can any1 let me know if i oni have RM 150 budget for 1 tyre,which tyre is the best???195/50/15...thx....kinda freak me out when ps3 now is at least Rm 260.....zzzz,front using ps3,back my01 but burst,so i need to change 2 rear tires now,saga blm btw...thx
30,002
Yup, PS3 new prices are shocking......
Not too sure if you can get a decent tyre for RM150 is the 15" size nowadays, but the closest is the Kumho KU31 Vietnam made ones. Even this I think is over RM150.
Either look for Indonesian made or worst case, you may have to use China brand ones...
meltan7
620
32
Kelana Jaya
just checked a few tires at Ah Kit Seksyen 24 Shah Alam.
195/55/15 Toyo T1R - 370
205/40/17 Bridgestone RE001 - 360
205/40/17 Bridgestone RE002 - 370
30,002
did not follow BS RE-001 and 002 series as I find them over priced.
RE-001 was made in Thailand and for some sizes made in Japan
RE-002 Made in Indonesia? I think still Thailand, right?
30,002
Old price at time of launch 215/45/R17 already cost RM450, so 225/45 should be higher and with now new prices....
ikiey185
Jun 20, 2010
13
selangor
What...!??? That's damn cheap!! Regrets regrets... :bawling:
---------- Post added at 12:19 AM ---------- 6 hour anti-bump limit - Previous post was at 12:16 AM ----------
RE002 15" confirm Thailand or Japan mari only... If japan, was quoted RM430 in Rawang, so i settled with Thailand only... 17" can get 370...?? Then if 15" will be how much,...?? So sad, if know about this Ah kit place, hve already went n buy there
TheSquee
448
12
vr2turbo ,
what do you suggest as a good street performance tyre for 15" with good tyre wear rate.. just name me most of the good ones and value for money if you dont mind : D
anyways a friend of my told me to get yokohama parada.. said it's cheap and really good in wet and dry.. what ur opinion?
30,002
The 17" BS are cheap. but the 15" Toyo is really expensive.....
---------- Post added at 03:13 PM ---------- 6 hour anti-bump limit - Previous post was at 02:44 PM ----------
vr2turbo ,
Don't know what is your budget, but tyres that are good in performance are:-
Hankook V12Evo, Federal 595Evo, GY F1D5, Michelin PS3. Prices should be in that order too.
Since you did not indicate the size also, Roughly the price for 195/55R15, Hankook should be in the region of RM210 to 230 to Highest the Michelin PS3 at RM270 to RM300 depending where you source the tyres.
If cheaper as you mention Yoko Parada Spec II, this tyre thread design is fierce, asymmetric in pattern, I would say good dry grip. Wet grip have mixed reviews, and aquaplaning resistance is so so only because no straight grooves and neither directional to cut water. One thing it is cheap but made in Philippine and is very noisy.
Another you can look at is the Kumho KU31.
Falken ZE-912 used to have a good following but recently some of the sizes had their traction rating changed from AA to A only, and some mention lack some grip already.....
There are others like BS RE-002, Yoko S-Drives and Toyo T-1R but these are in the over RM300 range.....:banghead:
Supra_Fanatics
20,685
3,998
Falken ZE912 thread wear is quite high...mine use about 1year only, need to change
soon adi...but the thing I like about it is ya quite grippy and it has this marker
where they call it fish eye if not wrong. The shape of the marker will change gradually,
and each changes tells u that is time to do alignment. :top:
30,002
Yup, round then square or something, but I think more for rotation, and yes a lot of feedback on fast wear.....
30,002
Try Nexen (Korean), Archilles (Indonesian) and if really want cheaper, then Chinese ones, but these Chinese tyres are cheap only, dare not comment on it's performance.....
hi all,
i facing this weird problem. i have an apexi turbo installed for the last 2 years and it was working fine.
until this week, the timer function most of the time was not working anymore. when i off the car, the timer's screen go to the timer section and it off before the count down start >.<
i have redo all the connection but it still having the same problem...weird case it do work once in a blue moon (1%). fyi, i also ground the grey wire (connect to handbrake) so that the...
