Absorber and spring for wira se 1.5 2005
K3NOT
Sep 10, 2011
6
Hi all ZTH members ... Good day
I need an advice from all sifus here :adore:
What is the best brand absorber and spring for my wira SE 1.5 year 2005?
I need a comfort ride, not so hard.
TQVM
LeBronJames
Nov 14, 2011
20
503
Try APM performax (red) absorber and just use back your original spring black. No need to buy APM performax spring (red), sux low and bumpy. Don't change to adjustable, very hard compare to stock. Case close.
Short stroke abs + original springs isn't that good a combo la.
2005 Wira SE - does it have the shortened fat front springs or has it been changed to the standard 1.6 springs?
If you want comfort with some degree of performance consider the Improve Comfort absorbers paired with the original springs.
If you're not into performance at all and want pure comfort - stick back to Kayaba ori absorbers with original springs.
If you have a lot of money to burn, consider Koni absorbers + Eibach springs.
K3NOT
6
u mean the same like the original? or harder than original?
I dont know how the original abs feel becoz just bought this car 2nd hand with stock abs.
I think same like original is good, am I right? :confused:
Is it good to buy the original OEM absorber?? :confused:
---------- Post added at 09:19 PM ---------- 6 hour anti-bump limit - Previous post was at 09:15 PM ----------
Thank you for the info.
But how do I know the spring can be use again or not? :confused:
---------- Post added at 09:23 PM ---------- 6 hour anti-bump limit - Previous post was at 09:19 PM ----------
Thanks for the good tips.
I dont know whether it have the shortened fat front springs or not. but the previous owner said that he never change the absorber or the spring. Now the car is bumpy.
Depending on year, the Wira SE had different things changed out. I suspect the suspension should still be the same. I'm using Improve comfort + original springs and it's pretty comfy. But bumpiness is subjective so until you test it you'll never really know what you want.
Similar threads   Forum
Proton
Looking For
Car Modification
  Similar Threads
Proton
Looking For
Car Modification
i have just replaced my blades with denso blades. my problem is that whenever it rains the blades 'skip' on the windshield. this does not happen when it is dry. however, there is no problem with the wiping action besides that.
anyone has any solutions to this problem?
