Polish manufacturer Arrinera finally unleashes their very own Hussarya supercar that’s been named after a 12th century Polish cavalry, the Hussars, after four years of development.
So it looks may take after a certain manufacturer from Sant’Agata, Bolognese, but one thing that helps to differentiate it apart is its active spoilers that deploy under braking and behind the Hussarya’s cockpit lies a 6.2L 650bhp V8 that helps catapult the 1,300kg supercar to 100kmh in 3.2s with a top speed of 340kmh.
The Hussarya’s two active spoilers serve as an air-brake at speeds beyond 150kmh that gets activated by applying the brakes. The spoilers deploy up to an angle of 50 degrees.
The Arrinera Hussarya will now be undergoing a battery of tests in Spain’s Applus IDIADA before it heads for production sometime in 2013, to be assembled in Poland by a division of Germany’s MAN Ferrostaal.
Arrinera Hussarya Specifications:
Length: 4,450mm
Width: 2,056mm
Height: 1190mm
Wheel track front: 1,744mm
Wheel track rear: 1,744mm
Wheelbase: 2,695mm
Engine capacity: 6.2L
Engine: V8
Power: 650bhp
Maximum torque: 820Nm
Gearbox: Graziano
Weight: 1,300kg
0-100kmh: 3.2s
0-200kmh: 8.9s
0-200-0 km: 14.3s
200-0 kmh: 133m
1/4 mile time: 11.0s
Max. speed kmh: 340s
Lateral g-force: 1.3g
http://youtu.be/6k6YgzrAJJo
