just drop ur msg or pm me,i will reply as soon as possible,normally KL area
10s :P
local,japan,korea & others continental spare parts are available
(p1&p2,toyota,honda,nissan,mitsubishi,daihatsu,ford/mazda,citroen,fiat,kia,hyundai,cherovet,merc,bmw etc)
wat i have:
1)engine parts-engine overhauled set,water pump,engine mounting,timing belt kits(mitsuboshi,gates,gates racing,eontech& ori etc,60k & 100k available)
mitsuboshi "A" dealer in kepong area
mitsuboshi url--> http://www.mitsuboshi.com/ (for nation car 12v 60k complete kits + installation =rm150, 100k complete kits + installation= rm200)others model available 2
gates xtreme performance tmg belt for 200k mileage --> http://www.gatesunitta.com/index.php
>made in japan
>3 times more stranght&durability
>designed specifically for turbo-charged or modified engines
>withstands EXTREME engine temperature
http://i2.photobucket.com/albums/y27/accordracing/GatesPerformanceBelt.jpg
-2)suspension parts-absober(monroe,gabriel,kyb,apm,tokico,apm performax,kyb rs etc),rubber mounting,rubber bush,lower arm,tie rod end,rack end,ball joint etc
promotion offer,superpro PU bushing(made in australia)
p/w1.3,1.5 gabriel absober rm400/complete set heavy duty hydaulic type
UR ultra racing performance bar
-fender bar
-frt&Rr bar
-upper arm bar
-room bar
-Rr anti roll bar
many model available,custom made also provide
3)cooling system-water hose,radiator fan motor,a/c motor,switch,radiator,thermostat,by pass hose,toyota coolant,nissan coolant,citroen coolant
4)maintaince parts-lubricant(shell,catrol,petronas,mobil,chemlube,honda etc),spark plug(bosch super4 rm55/4pcs,ngk laser platinum,ngk g-power rm50/4pcs,ngk iridium rm180/4pcs(free umbrella),denso iridium rm175/4pcs,champion plug),air filter,oil filter,fuel filter,oil treatment,gear oil,honda atf metal packing rm110/4L,toyota atf dextron 4 rm65/4L,honda cvt atf rm22/1L,fan belt etc
-battery MF(3k,enag & gp) special offer 4 zth member NS60 MF rm140,3k rm135(thailand import),others brand ns60 rm120/pcs,GP MF(made in korea) rm160,if u give me ur old battery discount rm5,1 year warranty given
SLICK 50 engine treatment available also
PROMOTION
-BP visco 7000 5w/40 fully sync rm109(current market price rm119)
-Castrol fully sync EDGE 10w60 new packng rm110 limited stock,(market price rm129)
-genuine HKS 10w/40 SJ grade semi sync rm110(4 litre)/tin
http://i2.photobucket.com/albums/y27/accor...ng/oil10w40.jpg
-chemlube distributor at kepong area
chemlube fully synthetic organic ester based 10w30/1litre rm46
chemlube fully synthetic organic ester based 10w40/1litre rm44
chemlube fully synthetic organic ester based 20w50/1litre rm42
chemlube semi synthetic 10w/40 rm95
picture-->http://i2.photobucket.com/albums/y27/accordracing/chemlube3grade1.jpg
5)transmission parts-cluctch kits(asco,daikin,ori etc),daikin racing clutch hyper,racing,twin plate
6)bodyparts-mudguard,wind screen,panel,moulding,door regulator,head lamp,tail lamp etc
7)braking system-disc rotor,brake hose,brake master pump,brake pump,wheel pump,caliber repair kits,brake pad(mintye,bendix metal king,ferodo racing,lucas trw,don,mintex,sumitomo)
8)accesories parts-latest toyota,honda fog light come wif bracket full wiring(vios,altis,camry,accord,civic,city,civic99, crv etc),angel eye spotlight(7 color without white),aluminium lock nut,HID kits,stylish head lamp/tail lamp,spoiler abs(accord,city,crv,x-trail,vios,altis etc),aluminium spoiler,sportrims aluminium nuts,strobe light "u" bulb rm160
PHILIPS distributor
performance bulb
-vision plus
-blue vision 4000k
-crystal vision 4300k
-diamond vision 5000k
-silver vision 4000k
9)car care product-black magic,crc,soft 99,stp etc
special add on:
suspension-brand available panther.rg sport,koni,hot bits,sachs,hwl,gab sprg,gab absober,gab adjustable,eibach spring,tanabe japan,arh absober,pu bushing,meter,k&n air filter
others-blow off valve,turbo timer(special feature got tachometer,can set a specific rpm n sound came out)1/2 warranty given
http://i2.photobucket.com/albums/y27/accordracing/Image7.jpg http://i2.photobucket.com/albums/y27/accordracing/Image5.jpg
credit card acceptable,delivery is available,need charge for certain distance
if interested kindly fone/sms me 012-2363293/016-3282268 zendengoh,msn contact [email protected],location KL kepong, website:http://www.zhapalang.com.my
Partnering Sellers/Merchants:
>> http://zerotohundred.com/newforums/search.php?do=process&showposts=0&starteronly=1&exactname=1&searchuser=c-ground
>> http://zerotohundred.com/newforums/search.php?do=process&showposts=0&starteronly=1&exactname=1&searchuser=HMS
>> http://zerotohundred.com/newforums/search.php?do=process&showposts=0&starteronly=1&exactname=1&searchuser=Rock+Lee
10s :P
wat i have:
>made in japan
-fender bar
-frt&Rr bar
-upper arm bar
-room bar
-Rr anti roll bar
PROMOTION
PHILIPS distributor
performance bulb
-vision plus
-blue vision 4000k
special add on:
