[WTS]: Shifter Plate Stabilizer
whatdamn
Cheras, KL, Mal
hey all,
What you see below are T6 aluminium bushing replacements for your shifter plate. Currently available for Manual Transmissioned Proton Wira, Satria and Putra. Others would depend on the shifter plate type.
so 8 pieces you'll see in the pics will cost RM 95.
with bulk comes lower rates. so feel free to bulk with your friends and PM a list ok?
payment will either be COD or if it's bulk then bank into my Maybank account.
feel free to call/sms me, Nick @ 016.274.63.97
these are most probably what your bushings look like:
you'll get 4 sets of these:
side view once fitted:
top view once fitted:
call me to get them!!!
i feel that shifting has improved alot. and you will feel more confident that you're shifting into the right gear. :)
tonychopper & harith,
it would help if you guys could send me pics of your shifter plate indicating clearly the type of plate/mounting/bush it is currently using.
as of now, we only have the design available for proton putra, satria and wira as they all share the same shifter plate.
btw, prices may vary with other car models not listed.
shifter plate
HI,
Did you have stock perdana V6 one?
how much?
tq
This kind of thing, I had been installed at the S15 before. So may i ask that... when after install it, will it produce the sound "klak. klak" when changing the gear? :emoticon_U:
i dun understand
wat this thing does?????
where does it installed??
v6tt909,
we can make one for you. price should be between 95-100 MYR.
scomatic,
that clacking noise you mentioned is not the fault of the gear, it's because the shifter plate is contacting the chassis. so, whenever you shift, the vibration will cause a very mild clacking noise. do not be alarmed, as that is the reason why rubber bushes were installed, to reduce noise! but you want performance, so you have to trade a little.
xcheong,
these T6 Aluminium bushings are a replacement for your shifter plate's rubber ones. do you know what a shifter plate is? well, it's the plate that holds the gear shifter stick and all the linkages. only applies to manual transmission cars. the purpose of this device is to give you a better feel when engaging/shifting gears. what i mean by feel is that you will most of the time engage the right gear and feel where/and when to shift into the right gear.
*bump!*
Bro,
what type of material you using for tht busing...??? did you custom make any pulley...???
Pls advice...
raymond,
material used is T6 aluminium, so rest assured that it will last and will not rust. and no, i don't make pulleys as that would require some calculations which i'm not willing to do at the moment due to my studies taking up most of my time. thanks.
bump!
for proton only at the moment. however if you have a sample of the bushing, we can make one for you however prices may differ. pls read the first posting as most of the info is stated there. thanks.
*bump!*
So how much royalty do I get since my name and blog is mentioned in your post?
llsaw,
aiyo, need or not. just mentioned your site since i noticed it there as well. something ppl can relate too. however, if you're unhappy about it pls let me know by PM. i'll remove all mention of your name and blog. sorry ya.
Well, it would be decent and courteous if you'll at least let me know in advance when you're going to mention me and my article in a commercial posting...
llsaw,
sorry man. just didn't think i'd infringe anything by casually mentioning your blog. no hard feelings k? great blog btw.
