Suppression Pad
SoundBlok Noise & Vibration Suppression Pad is a self-adhering vibration & resonance defeating material that is applied onto a vehicle’s door, roof, fender & rear quarter panel to suppress structural, engine & road borne vibrations. The convenient hand sized pads are ready to use with one surface coated with pressure sensitive adhesive that can be applied onto any panel, resulting in a good degree of noise and vibration control in a vehicle. It can also be added-on to bolster dampening points in the passenger compartment where the original melting sheets are too sparingly applied or are omitted altogether. It is made from a plastomeric based compound that is reinforced internally by a polyester fabric and has a protective polyethylene top surface layer.
Specification:
Thickness ........................... 3mm (0.12 inches)
Size .................................... 9cm x 18cm (3.5 inch x 7.1 inch)
Color .................................. Black.
Weight ................................ 3 kg/M2 (0.61 lb/ft2)
62g (2.2 oz) per pad
Water absorption ................. Softening Point ................... 155°C.
Tear Strength ...................... 400N
Tensile Strength @ 23°C ..... 14KN/m
Adhesive Type ..................... Solvent Acrylic 90 gsm
Adhesive Temperature ......... 150°C max. resistance @ 15min
Adhesion to Steel ................ 1.1kg/25mm
p/s : can stick anywhere inside a car...roof, door, fender.floor, rear bonet . so on.......
Price : rm45.00 per pack
Quantity: 10 pc inside a pack
Pm/SMS me at 0168362899
Postage to west malaysia is rm12.00
