[Urgent] Where to make Oil Cooler Lines?
DanzEterna
15,911
3,371
www.primeperdanaclub.com
If use garden hose clamps cannot meh? or maybe able to find a specific clamp at hardware shop,
buying a complete set is a waste of $$$.
u pasang the cooler edi ah?
No la, need to clamp the fittings ma. Sort of like metal fittings.
Those anodized ones.
I think you mean "crimp fittings" where you joint the hose and the ends together.
https://www.google.com.my/search?q=...m%2Fproduct_detail.aspx%3Fid%3D251634;440;285
Yup, some air con shops does it....
---------- Post added at 10:46 PM ---------- 6 hour anti-bump limit - Previous post was at 10:44 PM ----------
u pasang edi the cooler edi ah?
At first I also think can just go spare part shops get the hose clamps....hahahhaha:biggrin:
ken yeang
6,617
1,327
Stupidcar,
I oso made power steering line, ATF cooler line from that workshop too...
mosesmk
165
32
Selangor
Hihihi,
Anyone knows where to make oil cooler lines?
Or at least where to clamp those fittings?
Thanks.
Hi bro.
are you in klang valley? in shah alam there is one shop call Inland industrial Instrument. They are do lot of hosing work. Work next door to them last time. might it help.
Inland Industrial Instruments (M) Sdn. Bhd.
Address: No. 23, Jalan Juruanalisis U1/35, Seksyen U1, Hicom Glenmarie Industrial Park, Shah Alam, Selangor, 40000
Phone number: +60 (0)3 5569-5199
stupidcar
5,000 RPM
5,567
850
Hi bro.
Hey thanks.
Hihihi,
Thanks.
if clamp/hose type just use hose clamp and oil-rated hose
if the threaded type bring oil-cooler and screw banjo fitting to tracktor/jcb sparepart/machine shop and they will do custom hose for you....
One of my favourite jobs is headlamp restoration. Though it is hardwork and time consuming sanding with precision, the small area of work allows for undivided attention to perfect the process.
Headlamps turn yellow with age due to deterioration by the sun's UV rays. This is especially severe for most JDM and euro cars. This not only spoils the look of the car, but also reduces light output.
This time, the Evolution VIII MR
Note the blurriness and lack of clarity of the headlamp...
