Alo friends,
Engine and gearbox taken out from my car. Details:
Car Model: TA22
Engine Model: 12T (Size: 1588cc; Bore & Stroke: 85.0 x 70.0mm; same as 2T, using TTC-L: Toyota Total Clean Anti-pollution System - lean combustion)
http://ourworld.compuserve.com/homepages/stepho/eng2t.htm
Gearbox: 'Suspected' T50 with bellhousing for T engines
Why T50?
1. 5 speed manual;
2. Behind T engine (previous engine in car - 2T, second engine in car - 12T);
Looks like no details about the gearbox can be found on the VIN (Vehicle Identification Number) plate, coz TA22 VIN plate looks like this:
http://bekijk.mijn.celicas.nu/gif/Celica/TA22/fullsize/ta22-vin-2.jpg
Bellhousings for T, A and G engines seem to be compatible. http://ourworld.compuserve.com/homepages/stepho/engcodes.htm
So, if it's T50, I'm letting it go at RM200 (please take the engine also, can sell off the carb and new alternator). If not, I'll sell it to the scrap iron collector.
Pic of gearbox:
Car Model: TA22
Why T50?
1. 5 speed manual;
T50 alloy 5 speed manual, usually behind T engines. Major internal revision part way through Corolla AE70. http://ourworld.compuserve.com/homepages/stepho/engcodes.htm
The T-50 has a separate bellhousing, uses a hydraulic clutch and comprises 4 main alloy castings - bellhousing, two diagonally split front gear casings, and a tail housing. This gearbox is often referred to as the 'split case' alloy 5 speed, and weighs 29 kg.http://www.geocities.com/MotorCity/Garage/8422/4age.htm
Pic of gearbox:
