Mivec 4G93 - feeling of impact (hesitate/sag) when decelerating. PLS HELP!!
.:JiT_187:.
1,759
I think the best way to troubleshoot this is to experience it. We're guessing too much here.
Oh and there's still the possibility of fueling issues, specifically the fuel pump or injectors.
Agree, have to trouble shoot one by one since TS seems to have done some of our suggestions already and ours mostly guess work....
How can I check both condition?
Or need to replace it and test?
reset TPS position already yet/ (or recalibrate the tps reading first)
.:JiT_187:.
1,759
The tps is 0.5v when throtle body close…is it correct?
How to reset/calibrate the tps?
kayour
326
41
loosen the tps screw...then adjust it...cw/ ccw... to 05-0.6-0.7v...dun remember la
but from my experience...the problem when u touch the tps is when acccelarating 1000-1500 rpm
got jerking between that
then after calibrate tps...ok la
.:JiT_187:.
1,759
0.5v is ok then right?
Should i need to calibrate again?
set wot at highest 5v first...then check lowest value....
test drive... if not set 0.3v (or lowest possible) then compare at WOT if it gave 5v to make sure there is no performance loss
.:JiT_187:.
1,759
i have check the voltage for the tps,
throttle close-0.5v, throttle open-4.9+v
is it ok?
is it ok?
should be ok....or try slightly lower max value around 4.7v
.:JiT_187:.
1,759
.:JiT_187:.
1,759
coasting setting? but ecu is stock right?
hmmm, what cause engine braking...too much...
Yes…stock ecu
---------- Post added at 08:05 PM ---------- 6 hour anti-bump limit - Previous post was at 08:03 PM ----------
Since you are still having the problem, no harm trying or testing different settings....:driver:
What's the range for the tps value?
I got a Carvox CX-990 ( aka Radiostar King-Eagle ) 2 way lcd alarm a 2 month ago. I got it installed and it was working fine. Now it got cold the remote starter will not start. It only starts when the engine is warm. What happens wile the engine is cold is: it will crank for a second and shutoff and siren goes off at that time.
I got the system on ebay and got it professionally installed all together $300+
I took it back to the shop they checked and rechecked all connections for 2hr...
