>>i install brake pad D.I.Y yesterday<<
reddice
1,013
54
5,148
Tochigi Japan
japan.com
hye all,i hope someone can explain this.
im using satria and yesterday i change my brake pad by myself(D.I.Y),
after all complete,i test the car to do the bedding-in.(rataan lapisan :D )
i drive and brake for maybe 2 kilometres la..not braking so hard...then i come back home and thought everything is ok..BUT..when i touch my break disc,it is hot as hell,even my rims is hot!! :o only the front wheels,both of them..the rear wheels is ok..and there a smell..like something burning..i think maybe because of the break oil that get to the disc...and when i break..the oil burn..maybe la..but the main problem is the heat la..so hot!!like my rim just went back from hell !!
Any opinions?? <_<
malyadayada
361
u need to bleed ur brake fluid...
when the rims are hot meaning that ur brake is jammed...
that y u smell the burn n felt the heat....
better repair it or u will kill ur clutch plate aka burn ur clutch.. :o
reddice
1,013
54
5,148
Tochigi Japan
japan.com
waa!!that bad arr??i already bleed it la...ayyo..maybe the break is jam la...so,how?bleed and all the problem solve?? :(
reddice
1,013
54
5,148
Tochigi Japan
japan.com
i tot all disc is hot?
no,only the front disc !!!why does it effect my clutch???
and anyone can teach me how to bleed the right way???PLEASE !!!already done about 3 brake fluid bleeding in 2 week and the money is killing me !!! :blink:
badguy
951
which tyre are hot??
got any diferent on the brake pad dust?
my wira jam brake b4
i change the clipper which is jam and every thing solve!
khguan
4,818
26
Seri Kembangan
fotopic.net
new brake pad is thicker... so u have to remove some brake oil from de resevoir so dat it wun be too full...
when de pads r new... it new a run-in period... according to instructions.. u need to drive to 60 kmh.. n brake moderately until 20 n repeat for a bout 5-6 times...
dats my experience lar.. others i duno.. :)
reddice
1,013
54
5,148
Tochigi Japan
japan.com
already done the run in (bleed-in),i have to remove some break oil?so,no need to bleed anymore??aftre i throw some of the break oil??
the front tyres.both of them !! :(
badguy
951
how many years already your car!
maybe in brake line jam/stuck
after let go the hand brake can the car tyre roll easily??
or u feel like got some thing help u to brake????
reddice
1,013
54
5,148
Tochigi Japan
japan.com
after pull the hand break the tyres roll perfectly..but the hand break is locking the rear wheel right?the problem is the front wheel..maybe im wrong..
badguy
951
i mean after let go the handbrake
can all the 4 wheel roll smoothly??
or u feel like one wheel is jam hard to move???
u must feel it ur self
nuggyn
309
"so hot!!like my rim just went back from hell !!"
from the way your drove your car, maybe your rim did go back to hell :lol:
reddice
1,013
54
5,148
Tochigi Japan
japan.com
no,all the wheels roll smoothly..no wheels jam..it goes smooth..no stuck at all..
waa,i think constantine use my car to go to hell la..
I would like to check, how well is the aftermarket brake for 285mm rotor?
Is it about the same as stock?
my concern is, now my WHP is near 200 and i still using stock brake system.
my wheel is using 4 bot instead of 5, 2nd reason is i using 15" rims.
so if i using 285mm rotor type and branded caliper ( in complete set)
will it help for near 200 WHP? ( example evo, wrx, CTR are above 200hp and yet their stock already more then 320mm)
any recommend complete set brake for 15"
