help: nissan sentra ga16Dne
cebu
need help on how to set base idle and timing for GA16dne... i only saw instructions for GA16de in here... hope someone could help me. tnx in advance... :burnout:
i recommend pulling and cleaning the throttle and iacv assembly including intake manifold plus maf, prior to setting base idle and timing:
Preparation: Tools needed:
-set of flat & philip screwdriver
-6mm allen socket/ extension/ rachet handle
-pliers set
-cleaning materials
-lots of patience... :D
disconnect negative battery terminal
remove intake/ air filter housing
disconnect throttle cable / aac/ficd/tps/mafs connectors
disconnect coolant by-pass hoses big & small
bigger coolant-by pass hose sa left side
using a 6mm allen socket, loosen 4 TB mounting bolt
lift off the TB
see how carbon builds up in your throttle valve!
:D
no need to remove MAFS & TPS for safety reasons (baka masira pa)
remove AAC valve solenoid/ body by loosening 4 mounting bolts
use impact driver set kung pasaway, para di masira ang bolt
separate aac solenoid valve body from TB
dito dumadaan ang hangin para stable idling natin.
paano kung puno pa rin ng dumi..
:rolleyes:
remove ficd (fast idle control device) solenoid siya na nagpapataas ng idling kung i switch natin ang aircon o loads
ito yung nasa loob ng ficd. may spring, plunger at washer na pwedeng tumalsik... at dumi na kailangan tanggalin.. :o
eto naman AAC valve after removing 2 screws
tanggalin muna natin ang o-ring baka mamaga sa brake cleaner
:blah:
aac valve o-ring. i set aside
idle adjustment screw. ajust to set idling on engine. paano kung madumi rin... :o
always replace worn out gaskets.. kung hindi, idling issues pa rin.. :toink:
B)
for the dne, warm up engine to operating temp (until fans kick on)
rev engine 3 times not exceeding 4k rpm
turn off engine
disconnect tps
turn on engine
set base idle
then set timing
turn off engine
reconnect tps
Tevs
