[HELP] Iriz Rear End Hopping
Updates:
Readjusted tire pressure back to stock recommended settings.
Have been driving in and out for one week, rear skipping during cornering at commoner's speed (30-40km/h)is still noticeable.
Any advice please?
have u tried running the tyre pressure i've recommend above?
or try this pressure instead: 180kpa~200kpa max
6UE5t
6,756
1,300
Yeah skipping usually means it's a bit too stiff, can be from the suspension and/or the tires. Now since your suspension is still stock and normally stock suspensions are pretty soft already, then most likely is the tires, probably too high pressures and/or rubber too hard with poor grip performance.
Well, other likely chance is stock suspension jammed?
DNGFashion
95
508
Maybe I will go to ftuned to have the suspension system check and also at the same time check for any tyre failure.
Personally, I found that the stock tyre is incompetent
Will get back to everyone soon.
Thanks.
stock tyre is silverstone....definately it was on the stiff sidewall....
thats why i'm recommending lower tyre pressure than stock....
DNGFashion
95
508
Yeap I have tried your recommended tyre pressure, still it skips during cornering:confused:
sweelt
Nov 6, 2016
2,306
248
663
try open irix rear door. try sit/ press (left and right side) and see hows the rear suspension move up/down. Fast or slow.
Might be one side of the shocks/absorber give way.
6UE5t
6,756
1,300
Thanks.
It's a relatively new car so should not yet have suspension problems, let alone jammed suspension. If it does though, sorry to say that means the car quality is crap! I still think most likely is due to the shitty stock tires.
To us is likely the tyres or suspension. Since tyre reduce air pressure still like that , that is why maybe need check suspension....lol
Then next tyre change u can look into more comfort tyre category...
or to my earlier suggestion, change into a softer rear springs...
i believe that u were looking for better comfort?
Iriz original tyre size should be 175/65R14, tyre should not be that hard being 65 series aspect ratio?
DNGFashion
95
508
Personal check on suspension system: seems normal being not too slow and not too fast.
Tyre pressure: I have adopted the recommended range by pomen_GTR
Tyre: 195/55/15 silverstone, which I believe is a terrible tyre.
I'm actually prefer sport handling with little stiff ride.
If using 195/55R15 there are many tyre choices......:driver:
Hi guys,
I've been wondering about valet parkings around KL/PJ. I don't see a thread about it yet so do you guys think its a good idea to post a list of good and reasonable valet parking?
For me, some valet is reasonable enough to park and safe (especially during busy weekends and your car has some nice meters or ICE) - one is Sunway pyramid valet
Kindly list and comment for our shared knowledge and use.
1. Sunway Pyramid (rm 8-10)
2. Royale Bintang hotel (rm15) - anyone know any other...
