fender lamp
S1997
999
hi guys...any idea how to remove the fender lamp of wira? mine cover broken so want to replace with a new one.
thanks
Supachip
205
puucuung
I suppose u mean the signal blinker on the fender right? just open ur front door, after that, through the opening between door and fender, u will see the clip of the blinker, just use a long stick to give it a push then the blinker will drop out by itself.
khguan
4,818
26
Seri Kembangan
fotopic.net
well... there's another easier way to remove de lamp...
under de fender.. (above ur tyre) there is a plastic cover.. remove de screws so dat u can open a hole for ur hand to enter to push de clip n then de lamp is out...
ninja_iga
3,376
signal lamp?
next to headlamp?
that one, find the stainless steel wire with a loop in the engine bay side, right behind the lamp.
to release : pull it, and pull it towards the side. This will unhook the stainless steel hook.
I advanced the timing of my engine for better low end power. But due to that, the engine have clicking sound when i accelerate.
I think it is a slight engine knocking / pinging sound. It is acceptable to have SLIGHT/MINOR engine knocking? What is the side effects?
