Engine Oil Level High, How?
aakash27
Seremban
Hi guys, i searched thru the forum and didnt find any useful info so im posting it now.
What are the effects if i topped up engine oil more than the max level say by quite a bit? Any major effects on the engine?
Pls advise.Thx
No major effect...
Just ur car feels like very heavy onli...
Once feel heavy FC also increase...
What u need to do is find a clean big plastic bucket / container and release the engine oil a bit by a bit...or release all once shot also can and reput it back...
Good Luck...
ur engine will shake when u pickup, & when u hard press the pedal....
will kill ur engine coz of lot of bubble will be form...
just suck it out..
is it so serious? normally my oil level is slightly above the dip stick after oil change, never had any problem. i tense to lose some of the oil after few session of hard driving.
best is to put it slightly below MAX level....
in case u worry the oil will reduce over time, just top it up when necessary...
synthetic and semi synthetic oil will evaporate when it is hot................
but this is a slow process. make sure u tighten the oil cap, lipstick, breather line tightly. when the engine is oil the oil will sure reach higher than the max level. when it is cool, it will go down a bit.
agree.. agree.. my motorbike also, lighter a bit, hehehe..
make sure u dont top oil when the engine is hot. hehe.....
i also top up.
when engine is just shut off, the oil level is not accurate as the oil didnt fully flow back to the oil pan yet.
so u think it is no enuf and u add-up the engine oil.
so the next morning u check while engine is cold/before u go to work, u see ur oil level is too high n u blame ur mech overfill it
kekeke:rofl:
..............":boring:...just wake up in a very lousy city of Ukay this morning...:creep: going to check the oil level since last nite not enuf, i top up some...let see now enuf onot...:eek:wah!!! :stoned:why over fill so much???:questionmark:....cannot like this ma...bla bla bla :alberteinstein:...bla bla bla..4man useless put too much...bla bla bla..:motz:....&&$*(# cannot pakai punya 4man...:motz:......."........
like this..??:rofl:
i've been into that situation be4...my oil level is very low...so i when to my mech...ask him to top up a bit...since the engine car was hot..the reading on dipstick is not to accurate......then the next morning....Sh*T!!! my mech fill in farking too much...twice than full on the dipstick...fuel was farking high and performance was farking low...
hahahaaha.... who's fault..??hahahaha...:rofl::rofl::rofl:
hehe...it's all my foreman fault...wait2...but i'm the one who ask him to top up when the engine oil is hot...so it's my fault..eh..wait da minute...he suppose to know the engine is hot...so why wanna top up so much...so it's his fault... hahahaha...
its all bout weather...weather's faults..hahaahaha....
nono.......
its ur engine cooling system fault.
maybe u should use tufoil so it can bring down ur engine temperature. some ah mo ppl claim that they use tufoil and can get their engine with no water in the tank running for months. and yet the engine still OK!
probably the weather at ah mo there is not as hot as here. try ask the ah mo to bring his car to here to try run without water in the tank but with tufoil in the engine oil.
nono.......
HAHAHAHAAHAHAHAHAAHSHAHAAHAHAHAHAAHAHAHAHA....:rofl::rofl::rofl::rofl::rofl:
hahaha...r u sure they run the engine without any water on the radiator?? sound ridiculous..i also use tufoil but not dare to do smething like that...btw...my engine cooling system is ok...the problem is the valve seal...it needs to be replace...that y my engine oil starts to run low after 5000 km's of service...and also i like to rev my engine..resulting more engine oil to burn...
Write your reply...
