4g93p cams
xinghonh
xinghonh
1,415
7
isit possible 2 mod the cam's withouht replacing it wid a racing cam?
xinghonh
xinghonh
1,415
7
is there any disadvantages in doing so?
any place 2 recommend?
whatdamn
whatdamn
1,344
Cheras, KL, Mal
xinghonh,
most cams that you get locally such as powerzone ones are all reground cams. disadvantage as discussed in another thread is that you need to add washers to...pls use search button.
xinghonh
xinghonh
1,415
7
guess im not gud in using the search button....alwiz dun get 2 find wat i want
anyways if i juz install the powerzone cams...isit juz a plug and play thing?
which degree is the optimum if i wan low/mid range?
whatdamn
whatdamn
1,344
Cheras, KL, Mal
most will claim a plug and play application but you'd better ask them for all the little details. best if it's coupled by a fuel regulator and adjustable cam gears. just to be safe :) and also an safc while you're at it. unless you're going for really mild cams like less than 272 degrees. but if i were you, might as well get 272 straight away.
xinghonh
xinghonh
1,415
7
icic...my plans are getting the cams ..cam pulley then emanage....272...hows the idle?i heard frm ppl dat high cams makes the car harder 2 launch?isit true?how much improvement wud i get roughly?and wat bout the FC?thnx bro!
cooljas
cooljas
523
272 duration cams can idle perfectly with aircond some more! how much improvement will depend on ur cam setting n a/f tuning...more power means more petrol!
xinghonh
xinghonh
1,415
7
wa so meaning higher than that i wont be gettin any more air cond ar?
bro wat do u mean by cam setting?
a/f can be tuned by emanage rite?
i know dat my FC wud be terrible but how worse can it get?currently im gettin .19 cents per km based on RM1.92per litre
hello to all zth members.... my friend had a problem with his gearbox since he B.O.T. .. two times oledy his gearbox BBo0oo0mm!!!.... so, what type of turbo gearbox he can use ????? pls give your suggestion coz he need urgently... tq.. :smokin:
