afmarsyal
100
6
tps retard should be turn left (CCW)...
unker when wanna bring me go flash??...
i think retard is anticlockwise..because when i go clockwise to the maximum the throttle body butterfly valve also start to open..no need to piggy2back.. :)
Bump:
if tps retard, distributor advance or retard??
when i turn tps retard, car is just like jerking most of the time, an increase in torque i think, so i retard the distributor..because when distributor retard, it brings down the torque..
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
Bump:
yea... anticlockwise same as counter clockwise (CCW)....
ruckboyz_85
81
14
1,508
Need advice
Hi guys,
I'm newbie here...Need an advices from otai-otai here...which cam is better powerzone, maddspeed, piper or other brands?...which flywheel suitable for 4G13/4G15, flywheel 8", flywheel 8.5" or other sizes?..If i want to skim the flywheel, how much weight should i remove?...:hmmmm:
Bump: Hi guys,
biz-da-tech
520
for me if u on 4g13p just get semi racing clutch 1,5 CC kit can d. if u on 1,5 den upgrade 1.6 CC with the super touring flywheel
Bump: for me if u on 4g13p just get semi racing clutch 1,5 CC kit can d. if u on 1,5 den upgrade 1.6 CC with the super touring flywheel
tofu_manic
1,342
91
5,148
how much is ur budget for the cam?
if 1k++ then go for matspeed/powerzone, if lesser than 1k, pipercam....ive used pipercam, power increase is linear, pulls more to redline compared to stock but feeling is a bit flat....now using matspeed cam, more of a kick from mid to top end, powerzone, donno hehe never used
Bump: how much is ur budget for the cam?
afmarsyal
100
6
i've been planning to install a hi-cam as well..but some people say when install hi-cam, low rpm range will sucks..my cam now is standard, and the power kicks in somewhere at 2500rpm..if i install hi-cam will the power kicks in later, let's say 3500rpm? and if i install hi-cam, will i need to step harder on the accelerator in order to reach the 'power kicks in' rpm range or just step like i usually do but the engine will rev itself to the 'power kicks in' rpm range? need to clarify this..i don't want my car to be a stressful ride when driving in the city..it is where i dwell most of my motoring life..
khguan
4,818
26
Seri Kembangan
fotopic.net
it depends on how u tune the cam timing.
a long duration cam (or what u ppl refer as high cam) widens the powerband and we use the adjustable cam gear to shift the power band for better driveability.
yes.. the low end torque will suffer a bit.. especially u will feel your car a bit slower to move from stationery.. especially on a slope. If u get the cam timing right.. it wont affect daily driving much.
labulabi
78
matspeed..yummy yummy. kan tofu
afmarshall, when u say hi-cam, how hi? if 275 deg below(i still consider this as a mild cam), then dont need to worry about idling and driveability for normal road use. Hi-cam (292,304, etc) will produce hectic idling, no a/c etc = not really suitable for street use anymore. but what u'll get in return is a leap in hp and power at hi rev but sucks big time in lower rpm.
when will the power kicks in, well, that's when the ACP and a good tuner comes into play.:burnout:
ettm_14
605
81
yeah, guan yesterday I went and change my engine mounting, remember I said when I go through uneven roads, there is this sound like mouse in front(chik, chik, chik) it dissapeared for awhile, like one whole day.
today i drove my car, the sound came back?any ideas?not the suspension I quite sure about it...
haiz, super sien with the sound...
Bump: yeah, guan yesterday I went and change my engine mounting, remember I said when I go through uneven roads, there is this sound like mouse in front(chik, chik, chik) it dissapeared for awhile, like one whole day.
ruckboyz_85
81
14
1,508
Thanks guys for sharing the info..for the budget, use only for city driving.so i will choose to piper camshaft.its more cheap.but how about its durability?...need more info about skimming the flywheel..im using 4G13 vdo..thanks guys:driver::adore:
Bump: Thanks guys for sharing the info..for the budget, use only for city driving.so i will choose to piper camshaft.its more cheap.but how about its durability?...need more info about skimming the flywheel..im using 4G13 vdo..thanks guys:driver::adore:
Shinjite
864
120
Klang
WAAAAHHH....I sensed hostility here :P
*gets ready sheild*
*waves white flag* SAMA GANG, PROTON JUGAK!!! :thefinger::thefinger::thefinger:
hi, may i know where can i bored by throttle body? Any shop provide this service around PJ area? thanks!
