tofu_manic
1,342
91
5,148
eric,
it's on wheel bro... i just replaced my leaking downpipe today... i get even better power... makes me wanna go dyno again.. :biggrin:
wow dude, congrats congrats, very good results u got, never knew those oversized intake valves wud yield noticeable results for stocknia specs
lai lai come down to land of hornbill we frenly test test with my carb stocknia :biggrin:
ur power is really cun edi, with still many things that can be done, good job dude!
bro, you using stroker kit? if not, 2.0 piping ok ar for 1.5l?
no longer 1468cc dude, but 1.6 stock nia hehe
my 2 sen, if u have a 1500cc engine with a 28x/29x degree race cam and twin carbs then 2 inches would be quite cun
josephlauby
68
1,508
I'm willing to upgrade from time to time which does not tighten my income. I have a few options after following this thread closely.
(Main)
K&N drop in air filter
Iridium Spark Plugs (Wires remain ori if possible)
PZ extractor (4-2-1 as said to improve low - mid power & torque)
Mid bullet with some regular muffler
Lightened cam pulleys
With the upgrades above, will it increase revving potential?.
Bump: BTW, my 4G13 engine is using a Carburetor System
tofu_manic
1,342
91
5,148
(Main)
methinks u can save some money by skipping the iridiums, stock ones are good enough for the moment
the airfilter/exhaust combo is a good start, lighten cam pulley is not really needed, unless u plan to bring the powerband higher a bit but get a bit suckier low-end
to really get a nice bump in power, i would opt for 4g15 pistons, instant displacement increase, more torque, more hp
for better mid top with no significant loss of low end, then u can get some nice street cams like PZ 26x, or matspeed 272, with a cam pulley
with this, uve got a nice combo edi
my 1.3 also 2' piping maa..ok one :biggrin:
www.4g1series.cjb.net for more info....
urs was with twin carbs/full race cam, and donno what other secret stuffs la, cannot use for comparison :P
josephlauby
68
1,508
Tofu,noted. Will skip Iridium SP & Lightened Cam Pulleys for now. If i go for the below said upgrades, how much horses will I expect from my engine?.
4g15 pistons, instant displacement increase, PZ 26x, or matspeed 272, with a cam pulley,Air filter & Exhaust system.
Besides, do I need to proceed with thermal wrap on my extractor? As some mentioned that the temperature may rise too high which melts the aircond or radiator fan components. Kena once before about last year. The whole aircond fan motor melted beyond recognition.
Thanks forehand for the assistance.
khguan
4,818
26
Seri Kembangan
fotopic.net
i dont think 1.5 is suitable to use 2.0 inch piping. U will loose low end and the sound will be very noisy..
tofu,
y dont u come over here to test with us?? heheh... we got more cars over here... :biggrin:
Bump: i dont think 1.5 is suitable to use 2.0 inch piping. U will loose low end and the sound will be very noisy..
tofu,
biz-da-tech
520
bro guan, wat intake valve u using now ?
Bump: bro guan, wat intake valve u using now ?
afmarsyal
100
6
i'm having this problem too... i cannot retard too much or else have bad throttle response.... engine feels jerky at partial throttle...
i've finally found a solution, tps can retard but must be done along with the distributor..now my spark plugs all brown in color at the tip and no more crusty..throttle respons very much better, fuel consumption is so-so.. :)
fstr
7,935
954
Sahara Desert
tps retard - turn left or right?
btw, my ecu has been re-flash..now running 48psi (WOI) and 8k redline, now da injectors are splashing finer midst of petrol to burn efficiently, and did wide band tuning also.
i should say about 20-30% increased in performance overall and more fuel saving too.
for more info : www.4g1series.cjb.net
f.e.a.r
6
most of you stated that open pod air filter and exchaust mod are essential to improve the car performance. Can i know how much is needed for the open pod air filter and exhaust pipe mod needed?
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
you mean the price bro or what?
ettm_14
605
81
open pod alot of different brands and quality, should be in the range of RM300-350 without the rampipe, exhaust also the same, if you are going for a full exhaust, maybe 1000-1500?
Bump: open pod alot of different brands and quality, should be in the range of RM300-350 without the rampipe, exhaust also the same, if you are going for a full exhaust, maybe 1000-1500?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
tps retard should be turn left (CCW)...
unker when wanna bring me go flash??...
hi guys....
just wondering....
how much will it cost to rewrap a pair of front seats?
any recommended shops?
thanx :)
