Satria UK Spec
loose_end
Malaysia
I got a Satria 1.5cc 03/04 so-called know as " UK Spec Satria " .. i try to find any evidence around the car and the certificate , but there was no result stating it is " UK Spec Satria "..Therefore , do you guess have any idea what does this UK Spec mean?? and how to identify them..thanks
As wat i know Satria UK Spec do hv ABS like GTI..i owned a Satria UK Spec but already converted to GSR before sold it :biggrin::biggrin:to me..
mmmhh...the steering is a four spoke one...not 2 spoke...If im not mistaken la...
erm , mine got 3 spoke..sob..fake UK Spec??..any more things to identified ??..thanks
actually i own a normal satria, n my fren own a UK Spec Satria, i don`t really see any physical difference between us, but when i get in n try his car, his handling seems to be better
When I was shopping for a Satria..only clue that I could see if its a UK Spec or not is the ABS..and airbag? I dunno
Ya , i checked that earlier..I didn't see any thing stating it is UK SPEC also..but my friend said he identified it by looking at the colour , whereby the colour is GERMIS GREY..not sure wheather izzit true
my 96' Satria is a UK Spec Satria. The difference are:
1) Dual reading speedo meter. MPH is on top and more visible than KMH which is only small under the MPH numberings.
2) Also, not only the speedo meter is in MPH, the counter is also in Miles.
3) Aircond panel is different. It have "winter" button. When it turns to blue color, means you have cold air coming out and when it orange, it blows hot air.
4) Proton also installed an ABS-like brake assistant at the brake pump. But rosak already and i have removed it when i installed a new brake pump last time.
5) The dashboard panel is attached with carbon fiber like panel. Others 96' Satria is only fitted with normal black dashboard panel.
Thats only the differences. Owh yea, it comes with SRS airbag steering (4 spoke).
Hope that helps.
Well I had a UK spec Satria before. Light purple. Sold it on 2000/2001. Details are exactly the same as you had describe zedz. Another thing is, try to knock the body of the car. UK spec cars sounds much tougher coz they are made using a different body, tougher I guess. Is urs purple? It might be me old friend... :proud:
no. originally mine is White. Then i changed the color to black.
I prefer the UK spec than local spec Satria. It feels planted when cornering. But cons on the heavier feel.
I'm not sure bout this detail though, UK spec cars comes with a rectangular diamond logo instead of the usual karipap logos. Mine had rectangular diamond logo. Urs zedz?
i've changed my front hood and bumper and fender to mivec long time ago. heheheh..
but yeah, i do agree about the cornering. I am very confident whenever i hit a corner with high speed if I'm in my car. But i'm not sure that if because of the UK Spec or what because i never use other Satria so i cant compare.
Hope that helps.
Hello Guys..
I don't understand the first one about the MPH and KMH..sorry
I don't have any winter buttons
I do have the carbon fiber like panel
I don't have any airbags any the steering is 3 spokes..
Haha , Seems to be My "Fake" Satria UK Spec..:mad:
Bump: Does local spec satria comes with a front strut bar ?..
the MPH and the KMH is the speedo. U'll see two numberings of two different speed empirical units. If I'm not mistaken the larger ones are the MPH. Dont be pissed yet. Try to knock on the body and compare between the sound with a local spec. If urs sounds thicker, then safely its a UK spec. :proud: I guess..
Strut bar.. I can't remember... zedz?
i'm pretty sure that all satria uk spec have heater function in the cars la..
yes,fren of mine who own an UK spec satria has the heater & mph reading on the speedo
Hope that helps.
I don't think only UK model's have some of the function mentioned here. My 97 satria 1.3 has carbon fiber panel and SRS airbag steering. It also has this unique colour, i think it's called galaxy green and very few 97 and 98 models have it.
The 97 model for 1.6 has ABS too.
