- Joined
- Jan 9, 2006
- Messages
- 1,116
- Points
- 1,638
*Ps-PowerSport products supplied by us here are all new with warranty if fitted by our appointed dealers.*
Ps-PowerSport products had been arrounded & used by many people in many parts of the world since the 80's. So guys dont you worry about these tuning gadgets because this is not considering new products in our tuning industries already.
Guys, think for a second.Dont you need something that worth your money, friendly-tune enough to enhance your dream machine to higher levels. To me, i love big HP. But with big HP without liner HP output & responsiveness; cannot consider your machine in FINE-Engineering category. With PS-PowerSport tuning system here should be your solutions.
Item 1: Air Fuel Enhancer
Our tuning center have ever built a 6 cyls. Skyline engine which produced 1200HP utilised the original ECU and the Air Fuel Enhancer with very big 800c.c injectors. Can you imagine that? With the Air Fuel Enhancer, we can easily fine-tune the rough engine idle by just turning the idle knob. this rough engine definitely become steady idling with good response.
Please feel free to call me and make an arrangenment to see for your ownselves. It is universal fits for most cars.
Price: Rm8++
Item 2: EZY Launch Control
Keep launching rpm under control
This EZY Launcher [ELC] has been specifically designed to assist a race driver in the very moment of the start of a race. In high-powered racing vehicles, the driver has a very small threshold when it comes to acceleration. High power delivered by the engine to the gearbox and driven wheels can be great, but can not be easily managed even by the most experienced drivers to keep tires from hooking up at the line.
Price: Rm9++(include installation)
Item 3: Boost-Cut Eliminator
Universal fit for most cars.
* Avoids fault codes due to excessive boost reading.
* Stable & clean output signal amplification.
* Push engine horse power to higher level.
Price: from $360.00
Item 4: Speed De-Limiter
This PS developed unit which connects between the ECU and the Speed sensor is able to modify the signal, and allow the vehicle to be driven at higher speed than the preset speed which was limited by the vehicle manufacturer. [Please check part for correct installation of various vehicles] .
Price: from $380.00
Item 5: Digital Turbo Boost Controller [PN. DTB-303]
Suitable for most turbocharged cars including diesel turbo engine.
* 3 switch-able power level –NORMAL, LOW & HIGH
* Easy setting for accurate boost control up to 30 psi.
* Excellent power improvement.
Price: Rm1+++((include installation and tuning)
Comments:So far this is still the most accurate with rapid response boost pressure controller in the tuning market.
Item 6: High Heat Race-Gate [Racing used external wastegate]
Tough . Accurate . Reliable
The ‘PS’ High Heat Race-gate [HHR] set up to 1.9”, is a gadget of extreme reliability andenables performance of the highest standard for original or aftermarket turbo installations.
Its lightweight stainless steel valve with wide diameter diaphragms and spring plates are compatible with most high-speed reacting electronic boost control from the range of 200hp to 900+hp.
The by-product of any mechanical process is heat, which is the most obvious drawback of all exhaust waste-gate. HHR is enable to have the lowest operating heat around the exhaust side by utilizing the low heat transfer stainless steel components, a highest temperature resistance nomex diaphragm, and air-gaps below the CNC machined alloy pressure chamber, which acts to segregate heat away from the cast ductile iron base.
Fine boost pressure control can be maintained by adjustment of the top boost adjusting screw for boost in the range of 10 to 30 psi.Suitable for turbocharged cars only.
Price:Rm1+++
Item 7: Blow-off Valve - Mechanical piston type blow-off valve
The PS Brisk Dump-Valve [blow-off] features 100% CNC aluminum alloy - Aircraft quality construction with an attractive finish, adjustable, high-response unit for use on a wide range of applications from stock cars to high boost setups race cars. The 1" highest flow capacity piston inlet design also provides with ultimate smooth blow-off sound with its 4 round discharge funnels.
Generally large blow-off flow capacity valves have poor boost response, while smaller valves with good boost response are not able to handle high flow capacity – PS-PowerSport’s solution to this dilemma is by its well-engineered twin O rings sealed wide diameter nickel-chromed piston shape; which is enable to provide excellent Off/On discharge response without sacrificing any vacuum leak under both engine idle and high boost situations. It is also utilized the high heat stainless spring which constantly holding vacuum or high boost pressure at any engine temperature.Suitable for turbocharged cars only.
Price: from RM5++
Item 8: V-TEC Controller
* Allow VTEC transition point anywhere from 2800 to 7000 rpm.
* Avoid fault VTEC code due to system modification.
* Rev’ parameter only to activate VTEC system for stability & reliability.
Please check the correct parts for your type of car.Price:from $6++.
Item 9: Brisk Spark Energizer.
[/u]
* Improve engine power, fuel economy as well as lower emissions through efficiency as coil build up sufficient energy.
* Stabilizes new or aged ignition coil voltage to eliminate weak/miss fire especially at high engine revolution.
* Effective on standard or highly tuned engines for non-turbo/turbo & NOS applications.
* More spark energy than CDI ‘SHORT’ spark duration system. Ultra fast spark voltage rise time to meet engine requirements.
Can be universal fit for most cars with single or multiple coils.
Price:from $9++ up
Item 10: Electronic Blow-off valve device. [PN. DDV-25]
This is the best & could be the most expensive blow-off system in its range. Fast, accurate blow OFF or ON activation for demanded driver. Suitable to use for most turbocharged cars.
* Preventing back pressure exerted on turbo impeller.
* Adjustable valve sensitivity of electronically ‘DAMP’.
* Optional fitting of Safety OVER-BOOST protection setting.
Price: from 1480.00
Item 11: Sub-Fuel Injection Controller
* FINE adjusting fuel injectors pulse rates from the pre-programmed increase or decrease in MAP, IAT and RPM variation.
* Settable fuel load level from vacuum to a maximum of 30 psi high boost pressure.
* Provide extra fuel to prevent ‘Engine-Knock’ associated with high boost pressure increase.
* Rapid response each low or high ohm injectors with built-in flywheel circuitry for precision air/fuel mixture control.
* Retain great factory engine management system functions.
Suitable for super-charged or turbo-charged engines.
Price: from $1500.00 up.
Who wants to be the meanest,sick and twisted driver? Who thirst of BIG PONIES?
Your enguiry are always welcome!
Price: Rm8++
Price: from $360.00
Price: from $380.00
Price:Rm1+++
Price: from RM5++
[/u]
Price:from $9++ up
Price: from 1480.00
