Eh? The previous coment was dissepear?
ya wei.. all dissapear.
I said earlier your spark plugs costs a lotta money. And it's "Pedal" not "Paddle".
Please grounding only useful if stock one no good anymore due to corrosion or body damage/accident. And you realistically only need 3 points to ground, no need grounding kit la.
Want smooth clean tb, clean PCV valve, change new MAF/MAP, change new O2, change new ICV.
Are your k20 coil packs ok ah? Maybe one of your coilpacks are faulty
KHNG940413
668
56
johor bahru
Every year I will buy a bottle of Seamfoam Spray or CRC intake valve cleaner to do some cleaning(Alot of white smoke after doing it,but after awhile is gone). But haven't try to open out the whole tb to clean it. Where is the location for the stock grounding? I had search but didn't find it.
While changing the spark plug had check the coil all is running ok.
lsm1991
1,469
185
stock grounding is everywhere and everything... the entire car is ground, ur not likely to get much gains there,
dont see a point in doing this but u can just buy some of those grounding cables. dont need to buy anything branded, stock mitsus pakai the flat braided cable
White smoke Fogging mosquitoes.....hahhaha
Stock grounding usually 2 wires only. One from Battery negative point to chassis. One from engine to chassis.....
KHNG940413
668
56
johor bahru
yes,quite alot of white smoke
Me friends thought my car is burning engine oil. Need to drive abit aggressive to let all the smoke out.
I never knew there is a groundingfrom the battery to the chasis.Fail for me hahahhahahaha
Grounding from battery to chassis is the main one. The cable from engine to chassis grounding is much smaller.....lol
KHNG940413
668
56
johor bahru
Another thing I found out after changing to 16 inch rim
While going around 90~110km/h on the road suddenly uneven the tyre will scrap the fender abit abit lah.... I know is due to lowering spring or the travel of absorber is not enough.
But....ouch...my plan also consider to chg a set of adjustable ( Premium P6 adjustable is my consideration). In the mean time,drive slower I guess.
Hahahahahaha
Hahahahahaha
Your new rims offset must be more, since you did not change to wider tyres. Probably need to knock in you fender slightly.....
KHNG940413
668
56
johor bahru
Jazz Update
While cornering I hear abit scraping noise.So send to shop and check and this happened. The right side of my absorber mounting is rosak. Baru guna 1 tahun rosak already. I thought silicon type should last longer.Hahahahhaha
lsm1991
1,469
185
Jazz Update
maybe the quality of the silicone used isnt the best? silicone if keras kind, subject enough force onto it and it will give
alcyon
800
153
543
Hahahahahaha
You could camber your fronts a bit more in, or use a slightly narrower tyre to stretch the tops of your tyres inwards.
KHNG940413
668
56
johor bahru
After I change the absorber mounting and go back to the same road. It didn't scrap anymore. So.....my guess is due to absorber mounting.
Hi friends
I got to work on a BMW, my first German ride. In our small island, it embodies beauty, quality, comfort and pride.
However, its eyes have gone from worst to blinded. i had to restore the same with a little patience and a lot of passion.
Please enjoy the transformation..
Upon arrival
Headlights washed and clayed...
