Bro,vyrusj,
where does the air go in front? can't really see the opening.... or am I missing something ? hehe
I have not had any issue while driving thru heavy rain and thunderstorms. If you see the design of the airbox, the flow of the air come at the lower portion of the air box then goes up then only reaches the filter. The filter tends to get dirty fast, i blow clean the air filter every visit to the mechanic :)vyrus
the b-crew grill looks quite nice. More like a direct air intake. Did you have any issue when driving through thunderstorms or heavy rain? From what I know, stock air filter intakes are usually facing downwards so that it's difficult for water to go up the pipes. If it's frontwards, any issues?
I got it from another forummer when upgraded to open pod filter at RM8XX if i remember correctly. The nearest place to get it new will be in singapore. Try creating an account in Swiftclubsg and ask the merchant there - Project S. If not mistaken they have a partner here as well Trial Tuning. New ones will set you back for RM1.5K i think...Air filter getting dirty is better than water getting in. haha But yeah, I looked at your pic again, the air has to travel upwards at the engine section. Any idea how much is the b-crew grill setup, with the airbox and all that, and where can I get them?
Imprezho,
Hey, dude. Thanks for your comments. Yeah, most of the swift threads are dying or already dead. Even singapore's swift thread doesn't gain a lot of popularity. Kind of a waste because swift is actually a nice car to drive in, other than the occasional bad body roll and the bit of slack in over all performance.
1) Performance
I was reading your last line in performance;
"- Servicing done: HONDA 5W-30 engine oil, oil filter,air filter,NGK laser plugs,cleaned throttle body, 2 new ignition coil plugs,ATF oil, engine flush."
I was using suzuki engine oil because of the 8 free service coupons which covers oils and labour. I got 1 more service coupon to use so I might as well use the last one and after that, I plan to get my own oils, etc. some questions if you would not mind.
a) Do you get your own oil filter and air filter too? Or you use the ones that the service center/service shop provides?
b) Have you been using the NGK laser plugs for long time or you just changed it during the recent service?
c) Did you change the ignition coil plugs because it was time to change it, or was it to improve something in the car, or was it already becoming faulty?
2) Car noises. I'll try removing the driver seat and use wd-40.
3) Handling. I think your car may be built better than mine in this area as yours is CBU and mine's CKD. CKD probably stands for Che Kai Drivability. (che kai means lousy in cantonese) hahaha. Will add in the bars commented by ixeo in his post and see how much improvement i get out of it.
4) performance. I'll try out the Honda 5w30 oil that you mention probably in my next 2nd service. The upcoming one, i still have the free coupon so I'll just use that one more time. But I'll need to change the plugs because it's up to 35,000 kms and the plugs are not changed yet.
Thanks for your feedback. Will be back for more updates when I have them. :)
Ixeo,
Thanks for sharing. For the stabiliser bars, I'll keep in mind your advice on engine tower strut bar and rear anti roll bar. I've not sure if my swift already has a rear anti roll. I'll check it out later and if it doesn't have, I'll get that first.
For performance, I agree with you on the turbo. Pay big sum one time, get big power immediately (so to speak). Speedworks complete AXT turbo kit is RM8000, all in. They didn't say what's included in the "all in", though. Adding bits and pieces gets much less power but easier on the wallet. I don't actually intend to squeeze a lot of power out of this car because I am hoping to change a more powerful buy-n-drive car in about 1 or 2 years time. Maybe a car with stock 160 bhp, or something equivalent to a mazda 3 sport would also be fine. That's why I'm considering adding some bits and pieces for a bit more power on the swift for now.
By the way, I noticed that you sell Denso or Iridium. Some questions if you won't mind :)
1) how much are the iridium laser and the normal iridium plugs for swift?
2) what is the diff between laser and non laser iridum plugs?
3) any warranty? If yes, what and how does the warranty cover?
4) anything I should know before i buy and install it? don't worry, I won't expect 10% increase in bhp just from the plugs alone haha :)
Wow... u must be one of the first batch of Swift owners. I got mine in year 2008, current mileage is 130k km.Hi guys...glad to see Swifters around here...I've never met Swifters for real but for a good start, I think I should join this thread...feels the similarity...Mine is stock 1.5 2005 has clocked 205000++ km & has done some repairs on engine...
I also have the same issue about the performance...Modding cars is really fun to look at & I love to hear the sound of modded engines especially V8 & racing cams...If budget is an issue, can you guys recommend on which one would be the 1st thing that you do to increase the torque(engine response) & what are the next mods. Hopefully, this question makes sense... :)
1 - gearbox
2 - ECU
3 - camshaft
4 - others if any
thanks in advance for your replies.
I have change my coils during 80K km as well - same symptoms and issue with urs. Currently i am hitting 420-460km per tank on my daily commute from Seri Kembangan to Cyberjaya.Hey Dude,
1a) Yes i do normally use my engine oil and oil filters by myself as im just skeptical on getting from outside as i have my personal supplier that supplies lubricants,parts, wear and tear stuff.
b)Been using these plugs since my 70k mileage as i have just changed it at my major service 80k mileage strikes.
c)Ignition Coils were replaced due to abnormal jerking/ combustion problem at 80k mileage interval.Got it replaced with my plugs during this time as well.
**Updates so far for my swift observed at 82kmileage is that fuel consumption has improved alot as im clocking in at 380km for one full tank. Im yet to reflash my ECU to gain further improvements of this ride**
---------- Post added at 04:53 PM ---------- 6 hour anti-bump limit - Previous post was at 04:49 PM ----------
Guys,
It would be a great meet up for a drink to chillout and talk about cars too. It will be more like a small TT to intro ourselves and discuss ideas too
How is the price like? Downside of DK tuning is that he is located in Penang :( I still got few more wear and tear things to fix - engine mounts, lower arms, etc... before i can go for reflash.Nope not by DK tuning. Found a specialist named DESMOND from POWER AUTOHAUS in Sunway.
In the midst of getting it reflashed. Any one else interested?
How is ur brake feeling now bro? Now u have better braking, next up is the performance rite?wow suddenly swifters appear.. i was searching high and low for you all.. i thought nobody likes to play swift already.. where as in singapore still tonnes of nice cars here...
actually, i'm the 2nd owner and it reached 90k++ km when i bought it..to me, swift is rather fun to drive as compared to Honda Jazz 1.4...it might different if the engine was 1.5...Wow... u must be one of the first batch of Swift owners. I got mine in year 2008, current mileage is 130k km.
Hi Bro,actually, i'm the 2nd owner and it reached 90k++ km when i bought it..to me, swift is rather fun to drive as compared to Honda Jazz 1.4...it might different if the engine was 1.5...
btw, i don't know what IHE stands for? hehe..still a beginner & learning...
