German tuner, TECHART, keenly looking to reveal their latest offering of a Porsche 911 Carrera 4S has released pictures of it ahead of the Geneva Motor Show (2013) in bright emerald; sporting a body kit revision and equipped with a racing exhaust system.
The Carrera 4S has been dealt a revision to its front spoiler, side skirts, rear diffuser, larger rear-wing, blackened hood and a racing exhaust system with a pair of centred tailpipes that possesses valves to give the car a more throaty exhaust note.
There’s even a Noselift System that’s capable of raising the front by 60mm up front in order to make it a little more easier for navigating over speed humps while you roll on your choice of either 20″ or 21″ light alloy rims that’s up to 15% lighter than conventionally cast-alloy rims. The Noselift System can be activated via a button located on the centre console and once you’ve surpassed 60kmh, the system automatically lower itself.
The German tuner boasts that once you’ve gotten the 911 to speeds above 140kmh, the two-piece TECHART Front Spoiler I with integrated splitter helps to reduce lift by adding an additional 5kg onto the front axle, while the rear TECHART Rear Spoiler II (out of three types) that works in conjunction with the rear diffuser is able to generate 17.5kg of down force.
TECHART has even gone so far as to offer potential buyers with the option of out-fitting the interior with matching coloured trim in the form of similarly coloured accent stitching and the same effect can be had with the instrument cluster, while matte black paddle shifters behind a three-spoke steering wheel is also being served as optional extras.
