HondaMalaysiaNews
All Models From Honda Malaysia Are RON 95 Compatible – Except For The Type R
honda-accord-20-vti-l_front
Petaling Jaya, 26 August 2009 – Honda Malaysia today announced that all models distributed by the company are compatible with petrol RON95 (Research Octane Number 95). The Company announced this following the government’s decision to increase the price of RON97, along with the introduction of a more affordable option, RON95, which will replace RON92. The new fuel is available at RM1.75 per litre effective 1st September 2009.
As RON97 is most commonly used, many are doubtful in switching to fuel with lower RON. Honda Malaysia assured all Honda drivers that RON95 should not affect any model distributed by its authorised dealers with the exception of Civic Type R.
“Since 2001, all Honda cars require a minimum RON91, hence, any number above the minimum RON is safe. The switch therefore will not affect the performance and fuel efficiency of the vehicle. Compromisation of performance and fuel efficiency will only occur when the RON is lower than the minimum requirement,” said Mr. Toru Takahashi, Managing Director and Chief Executive Officer of Honda Malaysia.
“Except for Civic Type R, of which we recommend RON97 because of its high performance engine. A higher RON will thus produce more power for this performance sedan. Otherwise, the performance and fuel consumption may be affected,” he added.
In the event when fuel with lower RON is used, a condition called engine knocking will happen, which will result in reduced performance and fuel efficiency.
In order to prevent engine knocking, all models from Honda Malaysia are equipped with knock sensors. Knock sensors are detectors that signal engine operation to slow down the ignition timing (spark plug action) in case of engine knocking, which would consequently affect the vehicle’s performance and fuel efficiency. These knock sensors can also run on fuel with a minimum octane number of 91.
For models distributed before 2001 or distributed by non-authorised Honda dealers, owners are advised to cross check the vehicle’s minimum RON requirement by referring to their owner’s manual.
For more information, please visit www.honda.com.my or call 1-800-88-2020 for more information.
C
  • C
    Chan
  • Aug 26, 2009
can proton publish something like this also?saying all proton cars are RON95 safe?
K
  • K
    KS
  • Aug 26, 2009
Ofcos they can, if their balls are made of steel
C
  • C
    Chan
  • Aug 26, 2009
i mean can anyone ensure that proton especially GTI which is high compression engine can use RON95 and does not reduce shelf life after 2-3 year
Y
  • Y
    Yam
  • Aug 26, 2009
Pls take note some Iswara can't take RON95, must be 97+, my Iswara 1.3 required 97+. My Wira 1.6 OK with RON95.
A
  • A
    Automotive Jury
  • Aug 27, 2009
hello everyone..
my advice..use fuel with higher RON if you use a performance car/engine.
-The better RON (which mean a octane grade in fuel) means the engine will produce more power, better fuel economy, and longer engine life time (i mean service, you know what happen when you use RON92)..hehe.
-Better RON will produce less pollution.
-less engine knocking sound which came from explosion of air/fuel mixture in combustion chamber. Higher RON = great knocking sound resistance.
anyway..you still can use any type of fuel just "don't complain la kalau lain macam"..hehe.
Just to help..
D
  • D
    DC1
  • Aug 27, 2009
well i hv tried the ron 92 and it turns out it cost me more as fuel consumption does go up and thus cheaper so far to run on 97...
be interesting to test out the 95 to see hwo it goes.
again i do wonder how the quality of fuel to be at 95 or worst...
C
  • C
    crazy biscut
  • Aug 27, 2009
I read the headline "All Models From Honda Malaysia Are RON 95 Compatible.........Except For The Type R" MADE me laugh
L
  • L
    lightningfield
  • Aug 27, 2009
that means Integra Type-R and Accord Euro-R can use RON95! LOL
K
  • K
    Kasturi19
  • Sep 1, 2009
I'm using 1st generation CRV-1996 imported from Japan.
Can my CRV support RON95
K
