Kancil alternator vs L200s alternator vs big ampere alternator
chiewkit
14
Kepong, KL
www.geocities.com
Hi fellas!
wanna ask u guys, what is the ampere value for original Kancil alternator & Mira L200s alternator.
Is there any alternator that can used with Mira L200s engine that has bigger ampere??
Like wira you can fix in GSR alternator which have 130amp...
Any idea ah sifus?? :_:
ceo684
29
Is there a need for a huge alternator on a NS40 battery? NS40 w/stock alt already charges easily/fast..
chiewkit
14
Kepong, KL
www.geocities.com
Using new NS60 battery... still not enough charge... when switch on headlamp & step on brake... volt meter drop from 12v to 10v...
already have pivot VS & grounding cable installed... still not enough charge...
HPC and MAM's first ever 4 Endurance race in Sepang will commence this June 12th 2011. This will be a private event sanctioned by the Motorsports Association of Malaysia (MAM) and allows for all race prepared cars old and new ranging from 1600cc, 1800cc and 2000cc.
If you you have yourself a Honda Civic EG for example, your...
