Fire order 4G93 DOHC
Bremboy71
15
1,503
Anyone have a diagram of fire order for a 4G93 DOHC non Turbo? From Coil module to plugs.
Thank you.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
if not mistaken there is number stamped at the coil output nearby the spark plug cable....
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Usually should be 1-3-4-2 right?
firing order is usually 1-3-4-2 but probably the thread starter confused after removing all spark plug cable and scratching heads to reinstall correct cable position and length :hmmmm:
I used to label them before removing, but my cars now all different length so won't mix. With technology nowadays I just take picture with H/P then start to remove.....lol:rofl:
hye guys, im new here..hehe
just want to get some info bout the defrent between crossmember and subframe. because if want to transplant a myvi engine to kelisa engine bay will required to use storia or yrv subframe\crossmember rite?....den wats the defrent between kelisa and yrv\storia subframe\crossmember....very appreciated if could giv a details bout this....thanks...hehe
